Please clarify what version I'm on.
I see all of these thread topics about IoX, 3.1.23, 5.6.2  etc.
which PG3 am I on?
also:  on the different posts where the versions are announced, could you tell (remind) us how to update to that version?
(as an example, in this thread: https://forum.universal-devices.com/topic/41545-pg3x-version-3135-3136-july-11-2023/ it tells me to upgrade to 3.1.36 but I am only on 3.1.23 and I can't figure out how to get to 36.)
Solved by Geddy
@someguy looks like you’re on a Polisy and running PG3. You’re probably on the most current version for PG3. The release you linked to is for PG3x that until recently was only for eisy. You can move up to PG3x, but if you are still using PG2 then you shouldn’t because that will be removed.
You can always fine the current release announcements in this forum area:
https://forum.universal-devices.com/forum/339-current-release-announcements/
The current suggested/recommended method for updating is always through admin console using the “upgrade packages” in the Configuration tab.
You are on the most current version of IoX so you’re good there. (As of today!)
You can find how to move to PG3x in the wiki:
https://wiki.universal-devices.com/index.php?title=Polisy:User_Guide#Upgrading_to_PG3x
There are some posts about that from others that updated to PG3x so maybe read those posts. But just know there is no going back if you make the move and realize you didn’t really want to.
Once you’re on PG3x you would run the “upgrade packages” and it should bring you up to 3.1.36 (current PG3x version).
