Meross devices
Is there a simple path to get a Meross device to work on the eisy?  I have several in use at a cottage that has an Aeotec hub, and plan to put in the eisy next month for going forward use.
That depends on the technology they use. If it's zwave then they should add without issue if they use standard zwave commands.
I'd never heard of Meross, but it looks like many of their devices are wifi.  In that case if you can paste a url into a browser to control the device then it's pretty simply to interface to any IoX device using Network Resources.
Thanks both. I believe that it uses Wi-Fi.   I am not sure I understand MrBill’s response.  Is there somewhere I can read a briefing on loX devices?  Thanks.
