IoX disconnected
Everything had been running smoothly until I went to add a pair of KASA modules.  I noticed the packages needed updating so I did the update and two reboots, re-installed the node server(s) on the Polyglot (System - Reinstall) and noticed that the IoX was shown as disconnected now on Polyglot 3.  The nodeserver was not online on the admin console.  Re-booted a couple of times, powered it down twice, repeated the initial steps and I still don't have a connection.
Also, is it normal for the IoX Launcher to locate the ISY and still have the Finder say "Not Found"?
Helpful insight would be appreciated.  Thanks!
Solved by DennisC
You highlighted the error log that indicates to check your IoX IP address. Did you verify the IP address in PG3?
No, I didn't, but when I just went in to edit the current IoX configurations, I noticed that the address is set for the 127.0.0.1 and the HTTP/S was set for HTTPS.  I selected the HTTP and within a few seconds I was connected on both the admin console and the P3x.
That worked.  Thanks for the suggestion to look.  I wouldn't have thought of it without your prompting to look.
Thank you!  I think that I am good now.
