Ecobee v.3.14 nodeserver
Using 3.1.23 PG3.  Power in house failed yesterday and when Polyglot came back up, 6 nodeservers were all fine, but the Ecobee complained, and wouldn't start.  I attempted to restart, tried restarting Polisy - both to no avail.  Removed Ecobee. Then installed.  Shows status as Disconnected.  When I slick start which should give me the PIN, the node starts, waits 2-3 seconds and then stops
2023-08-26 20:57:25,113 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2023-08-26 20:57:27,554 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.1.0 Starting... 2023-08-26 20:57:27,624 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2023-08-26 20:57:27,625 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db9593250_1/./ecobee-poly.py", line 7, in <module> 2023-08-26 20:57:27,626 MainThread udi_interface ERROR udi_interface:write: from nodes import VERSION,Controller 2023-08-26 20:57:27,627 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db9593250_1/nodes/__init__.py", line 5, in <module> 2023-08-26 20:57:27,627 MainThread udi_interface ERROR udi_interface:write: from .Thermostat import Thermostat 2023-08-26 20:57:27,628 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db9593250_1/nodes/Thermostat.py", line 1 2023-08-26 20:57:27,628 MainThread udi_interface ERROR udi_interface:write: ormat(name)) 2023-08-26 20:57:27,629 MainThread udi_interface ERROR udi_interface:write: ^ 2023-08-26 20:57:27,629 MainThread udi_interface ERROR udi_interface:write: SyntaxError 2023-08-26 20:57:27,630 MainThread udi_interface ERROR udi_interface:write: : 2023-08-26 20:57:27,630 MainThread udi_interface ERROR udi_interface:write: unmatched ')'
Thoughts?
Solved by Jimbo.Automates
I upgrade to PG3x 3.2.2 and Ecobee problem went away.  Much appreciated.
