After Importing programs they are all disabled?
Hello,
I have 2 questions:
1. After having to delete all programs from ISY and re-importing them I noticed that most of them (not all) were disabled (the Enable check box was not checked). Is this common or could it be linked to question 2?
2. I tried to do a restore on the ISY after #1 above and it failed (something about socket error, sorry I didn’t write down the exact error). I rebooted the ISY and then was able to restore. I had the same problem when upgrading to 2.7.14? Could this be an indication of something failing, or is it a good idea, and perhaps necessary to reboot occasionally?
Tim
Hi Tim,
Usually if a Restore or a firmware upgrade fails it is due to one of three things:
Software firewall
Wireless connection
Network error (is the ISY connected through a switch?)
Rand
Hello,
I have 2 questions:
Tim
Hi Rand,
I am running McAfee and I disabled the antivirus and firewall, the ISY is connected to a port on the router directly, no wireless. Out of all the firmware upgrades I have done with the ISY, the last one was the first problem. The router is the dlink dir855 if that means anything.
Tim
