Moving Favorites from Polisy to new Eisy in UD Mobile
I have migrated from my Polisy to Eisy and I would like to move my UD Mobile favorites from Polisy to Eisy and remove Polisy from UD Mobile. Is there a secret? I have looked in help but no success..
Thank you...
Solved by Javi
Most favorites can be migrated assuming the node addresses are the same. Go to the existing system's  settings from UD Mobile >Settings Tab>Systems> Your System, scroll to the bottom and click clear UUID.
If you have local connection settings, set the Local IP Address for the new system.  If the app did not force you to select the system from Portal correct the remote url.  In Remote Connection Settings click the search icon next to the remote url  and select the new system. If using a different portal account delete the portal account from remote from remote connection settings and login to the new account.
https://wiki.universal-devices.com/index.php?title=UD_Mobile#Migration
