Tasmota PG3 Node Server Released
I have published a new node server for PG3 and PG3x that allows IoX to access and control Martin Jerry switches and modules pre-flashed with Tasmota as well as other Tasmota devices, such as the Shelly 1 module. Detailed installation instructions, release notes, and version history can be found here: https://github.com/Goose66/NSDocs/blob/main/tasmota-pg3.md.
The initial version is v3.0.4. Currently supported devices are:
  • Martin Jerry (MJ) MJ-S01 Switch (Switch)
  • MJ Plug V by MJ (Plug-in Module)
  • MJ US-SD-TC01 (Dimmer)
  • MJ US-FC-01 (Fan Controller)
  • MJ US-SS01 Switch (Switch)
  • MJ US-SS02 Switch (Humidity Switch)
  • Shelly 1 (Switch)
Edited by Goose66
