Where to purchase nodes on node server store.
I would like to purchase the Blink node server. I go to the node server store, find Blink, click information but there is nowhere to purchase or to activate. Am I on the wrong website to purchase the nodes? None of the nodes have a purchase button.
@Sidney Page You have to log in through the device you're on. Make sure you are logged into the web access to your device (for eisy probably https://eisy.local:3000 or use the device IP with :3000). Be sure to continue if/when you get a security prompt (see info in wiki link below). From there should be a link to the store and then a process to purchase and/or install will be in the node server (now plugin) that you want.
https://wiki.universal-devices.com/index.php?title=Eisy:User_Guide#eisy_(PG3)_Dashboard
(Note: some images might be outdated)
