Just bought an Eisy and need to migrate from isy944ir with wave.
I'm currently running 4.9.0 on my ISY944i and backed up my entire configuration to my hard drive.  I then booted up my new EiSY which is on 5.7.1 and logged into the pG3, and restored from by ISY backup.  When logging in using the IoX launcher, I only seed the programs have transferred.  Not a single one of the devices that are insteon.  Really no devices at all are showing up.  What am I doing wrong?   When I check the plm, it reads it.  When I select link, it beaps.  What do I do?  I was using the plm eth to eth on the isy944i, but I purchased the usb to eth connector for the EISY.
I am not sure I follow how you restored ISY backup from PG3?
Correct procedure is a little different depending on if you have only Insteon, ZWave, or both. You need to read and follow the directions. Here are the migration directions:
https://wiki.universal-devices.com/index.php?title=Eisy:User_Guide#Migration
In addition, if you have Insteon, you require a USB PLM or an adapter cable.
If you have ZWave, are you using UD ZMatter dongle?
