Curl to Network Resource translation
Did some searching but couldn't find anything of the sort - so here we are...
Got a Digital Logger's DIN Relay 4, trying to leverage Network Resources to trigger REST API call on said DIN Relay 4.  Using Curl on test box on the same network I'm able to have a relay fire, but can't figure out how to chop up the curl command into something for Network Resources to consume...Any ideas?
Working curl:
curl --digest -u admin:admin -X PUT -H "X-CSRF: x" --data "value=true" "http://10.10.10.10/restapi/relay/outlets/2/state/"
Thanks in advanced!
Solved by whywork
Found a work around in the mean time; Home Assitant + Wemo Relay Devices (Digital Loggers allows their relays to show up as a Wemo device).   I can setup the necessary automations in HA until i figure it out further with Network Resources.
Hi
I dont have Din Relay but do have Digital loggers web powerswitch
Here is the network resource i use to turn on outlet 3
GET /outlet?3=ON HTTP/1.1
Host: 192.168.1.174:8074
User-Agent: Mozilla/4.0
Connection: Close
Content-Type: application/x-www-form-urlencoded
Authorization: Basic (password is requested, then saved when setting up network resource)
