Ramp/On settings not working on 2477D
CTBigman
Go to solution Solved by gdntx,
Hello,
Have had an issue with my 994iPro not being able to set "on rate" on a 2477D. Just updated to the eisy with a new 2413s and everything seeks okay. Went to fix the issue with the ramp setting and it won't stick. 2-2477D controlling 2 recess in the MB that I want to come on at 25%. Now it gets weird, I can dim manually from both locations, when I turn the scene on from the bed it goes to 25% but if I try the switch by the door it goes to 100%?? The switches are actually on different circuits, the switch by the door is on an AFCI breaker and the switch by the bed isn't. If I run the scene from Iox it goes to 100%. Load is at the switch by the door. I have defaulted the switches and the scene have also deleted the switches and started over fresh and get the exact same result. What next? I don't understand how to decipher the event viewer but I see "Link not Found"? The first group is on/off at the door, second is on/off at the bed.
Thanks in advance,
Sat 01/13/2024 01:06:36 PM : [INST-SRX    ] 02 50 58.9E.2D 00.00.01 CF 11 00    LTONRR (00)
Sat 01/13/2024 01:06:36 PM : [Std-Group   ] 58.9E.2D-->Group=1, Max Hops=3, Hops Left=3
Sat 01/13/2024 01:06:36 PM : [D2D EVENT       ] Event [58 9E 2D 1] [DON] [0] uom=0 prec=-1
Sat 01/13/2024 01:06:36 PM : [58 9E 2D 1      ]      DON   0
Sat 01/13/2024 01:06:36 PM : [D2D EVENT       ] Event [58 9E 2D 1] [ST] [255] uom=100 prec=0
Sat 01/13/2024 01:06:36 PM : [58 9E 2D 1      ]       ST 255 (uom=100 prec=0)
Sat 01/13/2024 01:06:36 PM : [D2D EVENT       ] Event [58 A0 82 1] [ST] [64] uom=100 prec=0
Sat 01/13/2024 01:06:36 PM : [58 A0 82 1      ]       ST  64 (uom=100 prec=0)
Sat 01/13/2024 01:06:36 PM : [LINK-INFO       ] Link for responder 58 9E 2D 1 not found
Sat 01/13/2024 01:06:36 PM : [INST-SRX    ] 02 50 58.9E.2D 70.8A.A1 40 11 01    LTONRR (01)
Sat 01/13/2024 01:06:36 PM : [Std-Cleanup ] 58.9E.2D-->ISY/PLM Group=1, Max Hops=0, Hops Left=0
Sat 01/13/2024 01:06:36 PM : [INST-DUP 2  ] Previous message ignored.
Sat 01/13/2024 01:06:37 PM : [INST-SRX    ] 02 50 58.9E.2D 11.02.01 CF 06 00           (00)
Sat 01/13/2024 01:06:37 PM : [Std-Group   ] 58.9E.2D-->11.02.01, Max Hops=3, Hops Left=3
Sat 01/13/2024 01:06:37 PM : [INST-INFO   ] Previous message ignored.
Sat 01/13/2024 01:06:39 PM : [INST-SRX    ] 02 50 58.9E.2D 00.00.01 CF 13 00    LTOFFRR(00)
Sat 01/13/2024 01:06:39 PM : [Std-Group   ] 58.9E.2D-->Group=1, Max Hops=3, Hops Left=3
Sat 01/13/2024 01:06:39 PM : [D2D EVENT       ] Event [58 9E 2D 1] [DOF] [0] uom=0 prec=-1
Sat 01/13/2024 01:06:39 PM : [58 9E 2D 1      ]      DOF   0
Sat 01/13/2024 01:06:39 PM : [D2D EVENT       ] Event [58 9E 2D 1] [ST] [0] uom=100 prec=0
Sat 01/13/2024 01:06:39 PM : [58 9E 2D 1      ]       ST   0 (uom=100 prec=0)
Sat 01/13/2024 01:06:39 PM : [D2D EVENT       ] Event [58 A0 82 1] [ST] [0] uom=100 prec=0
Sat 01/13/2024 01:06:39 PM : [58 A0 82 1      ]       ST   0 (uom=100 prec=0)
Sat 01/13/2024 01:06:39 PM : [LINK-INFO       ] Link for responder 58 9E 2D 1 not found
Sat 01/13/2024 01:06:39 PM : [INST-SRX    ] 02 50 58.9E.2D 70.8A.A1 40 13 01    LTOFFRR(01)
Sat 01/13/2024 01:06:39 PM : [Std-Cleanup ] 58.9E.2D-->ISY/PLM Group=1, Max Hops=0, Hops Left=0
Sat 01/13/2024 01:06:39 PM : [INST-DUP 2  ] Previous message ignored.
Sat 01/13/2024 01:06:39 PM : [INST-SRX    ] 02 50 58.9E.2D 13.02.01 CF 06 00           (00)
Sat 01/13/2024 01:06:39 PM : [Std-Group   ] 58.9E.2D-->13.02.01, Max Hops=3, Hops Left=3
Sat 01/13/2024 01:06:39 PM : [INST-INFO   ] Previous message ignored.
Sat 01/13/2024 01:06:43 PM : [INST-SRX    ] 02 50 58.A0.82 00.00.01 CF 11 00    LTONRR (00)
Sat 01/13/2024 01:06:43 PM : [Std-Group   ] 58.A0.82-->Group=1, Max Hops=3, Hops Left=3
Sat 01/13/2024 01:06:43 PM : [D2D EVENT       ] Event [58 A0 82 1] [DON] [0] uom=0 prec=-1
Sat 01/13/2024 01:06:43 PM : [58 A0 82 1      ]      DON   0
Sat 01/13/2024 01:06:43 PM : [D2D EVENT       ] Event [58 A0 82 1] [ST] [255] uom=100 prec=0
Sat 01/13/2024 01:06:43 PM : [58 A0 82 1      ]       ST 255 (uom=100 prec=0)
Sat 01/13/2024 01:06:43 PM : [D2D EVENT       ] Event [58 9E 2D 1] [ST] [64] uom=100 prec=0
Sat 01/13/2024 01:06:43 PM : [58 9E 2D 1      ]       ST  64 (uom=100 prec=0)
Sat 01/13/2024 01:06:43 PM : [LINK-INFO       ] Link for responder 58 A0 82 1 not found
Sat 01/13/2024 01:06:44 PM : [INST-SRX    ] 02 50 58.A0.82 70.8A.A1 40 11 01    LTONRR (01)
Sat 01/13/2024 01:06:44 PM : [Std-Cleanup ] 58.A0.82-->ISY/PLM Group=1, Max Hops=0, Hops Left=0
Sat 01/13/2024 01:06:44 PM : [INST-DUP 2  ] Previous message ignored.
Sat 01/13/2024 01:06:44 PM : [INST-SRX    ] 02 50 58.A0.82 11.02.01 CF 06 00           (00)
Sat 01/13/2024 01:06:44 PM : [Std-Group   ] 58.A0.82-->11.02.01, Max Hops=3, Hops Left=3
Sat 01/13/2024 01:06:44 PM : [INST-INFO   ] Previous message ignored.
Sat 01/13/2024 01:06:46 PM : [            Time] 13:07:02 0(0)
Sat 01/13/2024 01:06:46 PM : [INST-SRX    ] 02 50 58.A0.82 00.00.01 CF 13 00    LTOFFRR(00)
Sat 01/13/2024 01:06:46 PM : [Std-Group   ] 58.A0.82-->Group=1, Max Hops=3, Hops Left=3
Sat 01/13/2024 01:06:46 PM : [D2D EVENT       ] Event [58 A0 82 1] [DOF] [0] uom=0 prec=-1
Sat 01/13/2024 01:06:46 PM : [58 A0 82 1      ]      DOF   0
Sat 01/13/2024 01:06:46 PM : [D2D EVENT       ] Event [58 A0 82 1] [ST] [0] uom=100 prec=0
Sat 01/13/2024 01:06:46 PM : [58 A0 82 1      ]       ST   0 (uom=100 prec=0)
Sat 01/13/2024 01:06:46 PM : [D2D EVENT       ] Event [58 9E 2D 1] [ST] [0] uom=100 prec=0
Sat 01/13/2024 01:06:46 PM : [58 9E 2D 1      ]       ST   0 (uom=100 prec=0)
Sat 01/13/2024 01:06:46 PM : [LINK-INFO       ] Link for responder 58 A0 82 1 not found
Sat 01/13/2024 01:06:47 PM : [INST-SRX    ] 02 50 58.A0.82 70.8A.A1 40 13 01    LTOFFRR(01)
Sat 01/13/2024 01:06:47 PM : [Std-Cleanup ] 58.A0.82-->ISY/PLM Group=1, Max Hops=0, Hops Left=0
Sat 01/13/2024 01:06:47 PM : [INST-DUP 2  ] Previous message ignored.
Sat 01/13/2024 01:06:47 PM : [INST-SRX    ] 02 50 58.A0.82 13.02.01 CF 06 00           (00)
Sat 01/13/2024 01:06:47 PM : [Std-Group   ] 58.A0.82-->13.02.01, Max Hops=3, Hops Left=3
Sat 01/13/2024 01:06:47 PM : [INST-INFO   ] Previous message ignored.
Try doing a restore device for (58.A0.82)
You also need to set the on levels and ramp rate, within the scene, for each device in that scene.
The on level and ramp rate for the switch, if you operate it outside of the scene, also needs to be set for the switch.
I will try a restore, the levels and ramp are set on the scene and at each switch in the scene. I also tried setting the on level on both switches outside of the scene and it won't update, stays at 100%..
No change with Device Restore. If I run the scene from Iox it works perfect as per my clip, but manually pushing the switch by the entry it goes to 100% ARGHH!
I'm not sure I followed all of the problem, but I had problems setting the On Level for a switch and just found it has changed in the SW.   If you are trying to set the local On Level for a switch, set the number to what you want in the console and then click the "On Level" button, not the "Write" button.    You may already be trying that, but it isn't intuitive.  I don't know when that changed, but maybe help for changing the settings of the switch.
@CTBigman As @Techman indicated you will need to set each device in the scene and you have to set Scene | Controller | Set for each device as well. This has to be done using the adjust scene function. As a reference you can read this post.
Adjust Scene
And here's the program that switches my hall lights from 100% during the day to 35% at night. This allows local control. Notice how each of the three switches has four program changes made to make this work. I have asked UD to make this more intuitive, but it's not really something that's a priority.
You really should only have to set Scene | Controller | Set once, but you have to actually call out every permutation possible to make it work correctly. Don't be fooled by some of these program lines looking exactly the same. the differences are in the adjust scene area not shown. Read the linked doc above.
2nd FL Hall Lights Power Setting - [ID 000A][Parent 001F]
        From    12:00:00AM
        To      Sunrise (same day)
        In '2nd Floor Hallway / 2nd Fl Hall Lights(M) West' Set '2nd Floor Hallway / 2nd Fl Hall Lights(M) West' To 35% in 0.1 seconds, No retries
        In '2nd Floor Hallway / 2nd Fl Hall Lights(M) West' Set '2nd Floor Hallway / 2nd Fl Hall Lights(S) East' To 35% in 0.1 seconds, No retries
        In '2nd Floor Hallway / 2nd Fl Hall Lights(M) West' Set '2nd Floor Hallway / 2nd Fl Hall Lights(S) North' To 35% in 0.1 seconds, No retries
        In '2nd Floor Hallway / 2nd Fl Hall Lights(S) East' Set '2nd Floor Hallway / 2nd Fl Hall Lights(S) East' To 35% in 0.1 seconds, No retries
        In '2nd Floor Hallway / 2nd Fl Hall Lights(S) East' Set '2nd Floor Hallway / 2nd Fl Hall Lights(M) West' To 35% in 0.1 seconds, No retries
        In '2nd Floor Hallway / 2nd Fl Hall Lights(S) East' Set '2nd Floor Hallway / 2nd Fl Hall Lights(S) North' To 35% in 0.1 seconds, No retries
        In '2nd Floor Hallway / 2nd Fl Hall Lights(S) North' Set '2nd Floor Hallway / 2nd Fl Hall Lights(S) North' To 35% in 0.1 seconds, No retries
        In '2nd Floor Hallway / 2nd Fl Hall Lights(S) North' Set '2nd Floor Hallway / 2nd Fl Hall Lights(M) West' To 35% in 0.1 seconds, No retries
        In '2nd Floor Hallway / 2nd Fl Hall Lights(S) North' Set '2nd Floor Hallway / 2nd Fl Hall Lights(S) East' To 35% in 0.1 seconds, No retries
        In '2nd Floor Hallway / 2nd Floor Hallway' Set '2nd Floor Hallway / 2nd Fl Hall Lights(M) West' To 35% in 0.1 seconds
        In '2nd Floor Hallway / 2nd Floor Hallway' Set '2nd Floor Hallway / 2nd Fl Hall Lights(S) East' To 35% in 0.1 seconds
        In '2nd Floor Hallway / 2nd Floor Hallway' Set '2nd Floor Hallway / 2nd Fl Hall Lights(S) North' To 35% in 0.1 seconds
        In '2nd Floor Hallway / 2nd Fl Hall Lights(M) West' Set '2nd Floor Hallway / 2nd Fl Hall Lights(M) West' To 100% in 0.1 seconds, No retries
        In '2nd Floor Hallway / 2nd Fl Hall Lights(M) West' Set '2nd Floor Hallway / 2nd Fl Hall Lights(S) North' To 100% in 0.1 seconds, No retries
        In '2nd Floor Hallway / 2nd Fl Hall Lights(M) West' Set '2nd Floor Hallway / 2nd Fl Hall Lights(S) East' To 100% in 0.1 seconds, No retries
        In '2nd Floor Hallway / 2nd Fl Hall Lights(S) East' Set '2nd Floor Hallway / 2nd Fl Hall Lights(S) East' To 100% in 0.1 seconds, No retries
        In '2nd Floor Hallway / 2nd Fl Hall Lights(S) East' Set '2nd Floor Hallway / 2nd Fl Hall Lights(M) West' To 100% in 0.1 seconds, No retries
        In '2nd Floor Hallway / 2nd Fl Hall Lights(S) East' Set '2nd Floor Hallway / 2nd Fl Hall Lights(S) North' To 100% in 0.1 seconds, No retries
        In '2nd Floor Hallway / 2nd Fl Hall Lights(S) North' Set '2nd Floor Hallway / 2nd Fl Hall Lights(S) North' To 100% in 0.1 seconds, No retries
        In '2nd Floor Hallway / 2nd Fl Hall Lights(S) North' Set '2nd Floor Hallway / 2nd Fl Hall Lights(M) West' To 100% in 0.1 seconds, No retries
        In '2nd Floor Hallway / 2nd Fl Hall Lights(S) North' Set '2nd Floor Hallway / 2nd Fl Hall Lights(S) East' To 100% in 0.1 seconds, No retries
        In '2nd Floor Hallway / 2nd Floor Hallway' Set '2nd Floor Hallway / 2nd Fl Hall Lights(M) West' To 100% in 0.1 seconds
        In '2nd Floor Hallway / 2nd Floor Hallway' Set '2nd Floor Hallway / 2nd Fl Hall Lights(S) East' To 100% in 0.1 seconds
        In '2nd Floor Hallway / 2nd Floor Hallway' Set '2nd Floor Hallway / 2nd Fl Hall Lights(S) North' To 100% in 0.1 seconds
I had a similar problem with a siren module.
Set it on the main entry but it didn't do what I wanted. Until I set it in the scene it was member of. Too my desired need.
Yeah, it's been awhile since I did any modifications besides schedules. I went back and looked at UDI youtube videos and they are so old and out of date they were no help. When is UDI going to update their videos, I think it would help their business immensely.
      378.6k
