Official Firmware Release: 2.7.15
Hello all,
Thanks to a lot of help and feedback from our user community, release 2.7.15 is now our official release. If you have 2.7.15 installed, you do not have to reinstall it again.
Release notes may be found here: http://www.universal-devices.com/mwiki/ ... tes_2.7.15
Instructions
1. Please backup your ISY (File | Backup ISY)
2. Please download the firmware for your platform - please do not unzip
a. ISY 26 - http://www.universal-devices.com/update ... nsteon.zip
b. ISY 99 - http://www.universal-devices.com/update ... nsteon.zip
3. It is very important that you use your current ISY's Admin Console to perform the upgrade by going to your http://your.isy.ip.address/admin. For MAC users, if upgrade fails, please try https://your.isy.ip.address/admin
4. Login to the Admin Console and choose Help | Manually Upgrade [the name of your system]
5. Choose the file saved in step 2
6. After the upgrade, ISY reboots. Please do ensure to clear your Java Cache:
http://www.universal-devices.com/mwiki/ ... Java_Cache
7. IMPORTANT Once upgrade is completed and ISY reboots, use any of the following methods to access your ISY's Admin Console:
a. http://isy/admin - applet (Windows only)
b. http://isy/admin.jnlp - Java application (Windows only)
c. http://your.isy.ip.address/admin - applet
d. http://your.isy.ip.address/admin.jnlp - Java application
e. http://www.universal-devices.com/99i - applet
f. http://www.universal-devices.com/99i/admin.jnlp - Java application
8. IMPORTANT If you have already installed a self signed certificate and your current firmware is 2.7.10 and below, you must reinstall a new one:
http://www.universal-devices.com/mwiki/ ... rtificates
9. General instructions (especially for adding V2 thermostats) for the new features in 2.7.7+ can be found here: http://forum.universal-devices.com/view ... hp?p=27368
Upgrading from 2.7.8 through 2.7.10
Upon reboot, ISY tries to migrate all configuration files to release 2.7.15 levels. This said, however, in the case of KeypadLincs, the following
settings shall be lost (ISY will be out of synch with your devices) for those KPLs that were setup/configured in 2.7.8 or 2.7.9:
a. Button toggle mode
b. Button backlight
c. Button groupings (in scenes or otherwise)
d. Button mutual exclusivity
As such, if you have setup any KPLs in 2.7.8 or 2.7.9, it's best to remove them from ISY, do a factory reset on them, add them back and reconfigure them.
Alternatively - and you have not made massive changes using 2.7.8/9, you can restore your 2.7.7 backup (File | Restore ISY) and let ISY migrate everything.
Thanks so very much for your help and support.
What if I'm still on 2.7.0, is there anything special I need to do or worry about besides just backing up my ISY?
The notes only talk about upgrading from 2.7.8 through 2.7.10.
Also, what do I need to do specifically to backup my programs? Last time I had a problem and tried to restore to a backup it did not restore my programs.
Hi Zick,
To backup your programs separately Select the top folder (My Programs), right-click to open the context menu, select Export.
There should not be any issues upgrading from 2.7.0.
Rand
Mac OS X Leopard 10.5.8
Access through Java Application:
Automatic upgrade failed at 13% due to invalid length
Manual upgrade failed at 13% due to invalid length
Access through browsers http and https with java preferences set to run within the browser process:
FireFox: Unable to access admin console
Safari: Unable to access admin console
Access through browsers http and https with java preferences set to run in their own process:
Safari:
http: Manual upgrade failed at 13% due to invalid length
https with timeout set to 25000: Success. Upgraded to 2.7.15
The previous statements are the same findings as the last few betas I have installed.
However, we have a new and much more serious problem.
I can no longer use the java application to access the Admin Console in 2.7.15 It now shows the same error regarding class file as the applet shows when trying to run the applet in the browser instead of in its own process.
The error is something like "unsupportedClassVersionError: Bad version number in .class file"
I have downgraded to 2.7.14 as it is too difficult to change the java settings anytime I want to access my ISY.
I am running Mac OS X Leopard 10.5.8
I have downloaded the very latest java updates from Apple.
In about the middle of March I upgraded to 2.7.12 from 2.7.6.
After the upgrade to 2.7.12, I lost the ability to directly access my admin console, I had to go through the universal-devices support website. I accessed my admin console just this past Monday evening, 3 May, using the Univ-devices website, without any issues.
As of the evening of 5 May, I can no longer get to my admin console at all. I get:
Applet com.universaldevices.client.ui.UDClientApplet notinited
at the bottom of the console window, using Firefox or Safari.
I tried following the advice above from "Illusion", and was not successful. I must admit, I do not know how to set "timeout to 25000" so I was not able to follow that part of the instructions.
This could all be a coincidence, or related to the new release. Any help would be greatly appreciated.
NOTE: My internet connection was both wireless and by cable, with no difference in the result.
Safari:
Hello justin.cool,
I do apologize for the inconvenience. The issue is that we need Java 6 functionality for the Admin Console and thanks to Apple, Java 6 32 bit support is only available on Snow Leopard (quite disappointing and frustrating).
We will try to see if we can bypass (or even write our own code) for those functions that require Java 6 on MAC.
Michel,
Thank you very much for the prompt response.
I can deal with having to get Snow Leopard, in the not too distant future. However, in the meantime, i cannot access my admin console at all.
I assume that when you say that you need java 6 functionality for the admin console, you mean for 2.7.15? As I did not have an admin console problem through Univ Dev website for 2.7.12.
Is it possible to fix the problem that prevented me from accessing the admin console directly (not going through the Univ Dev website) in 2.7.12? If that can't be fixed, i will have to go back to 2.7.6, and I have a number of newer devices, like dual band lamp lincs, upgraded thermostats, etc etc that could present a problem. Will all my programs still work if I go back to 2.7.6? But quite frankly, if I can't get to my admin console, I dont believe I have a way to go back to 2.7.6?????? In other words, HELP, please!
Justin
Hi justin.cool,
We are working on it right now. There are a few features that require 1.6 including network optimization, icon image for dialogs, table sorter, chart utilities, and many more.
In the meantime, you can always try the older UIs, for instance 2.7.14 or 2.7.12 by going to:
http://www.universal-devices.com/99i/2.7.12/admin.jnlp or
http://www.universal-devices.com/99i/2.7.14/admin.jnlp and so on and so forth.
Running Vista Ultimate and did the automatic upgrade through the admin console. Went very smooth!
Michel,
i ran:
The error description was:
"The application has requested a version of the JRE (version 1.6+) that is not installed."
Once again, I am running 10.5.8 Mac OSX, with the latest java updates from apple.
Here is the Java Exception message I got:
JNLPException[category]
at com.sun.javaws.Launcher.prepareLaunchFile(Launcher.java:681)
at com.sun.javaws.Launcher.prepareToLaunch(Launcher.java:309)
at com.sun.javaws.Launcher.prepareToLaunch(Launcher.java:214)
at com.sun.javaws.Launcher.launch(Launcher.java:107)
at com.sun.javaws.Main.launchApp(Main.java:405)
at com.sun.javaws.Main.continueInSecureThread(Main.java:252)
at com.sun.javaws.Main$1.run(Main.java:111)
at java.lang.Thread.run(Thread.java:613)
Just for the heck of it, I ran:
http://www.universal-devices.com/99i/2.7.6/admin.jnlp
Which was my last fully functional firmware version. (Ie could access admin console directly from home computer, OR from Univ Dev website). I got the same error.....
[/u]
I'm trying to upgrade my ISY-99 to firmware version 2.7.15 and I keep getting an error message "Upgrade Failed Invalid Length" Any ideas about how to resolve this? I'm currently at 2.7.14
I just upgraded to 2.7.15 and the process went very smoothly.
I just have one quick question (...so far...):
With regards to thermostats, I read this:
The thermostats are represented by 4 nodes:
The main node - this is the main thermostat node
xxx - Cool Control - indicates when the thermostat is calling for Cool
xxx - Heat Control- indicates when the thermostat is calling for Heat
xxx - Fan Control - indicates when the fan is on/off
Where am I supposed to see all these nodes?
Right now under "My Lighting", I have a device named "Thermostat" (2441V INSTEON Thermostat Adapter v.28).
But, this is the exact same thing I had on older versions, so I don't see any change.
Am I missing something somewhere?
I did follow the instructions and UNLINK the thermostat and then added it back in while it was 'off'.
Thanks in advance for your help... and keep up the great work!
After upgrading to 2.7.15 the strangest thing happend. I have two v2 thermostats that where installed correctly under 2.7.14 with the four nodes. After upgrading to 2.7.15 one of the thermostats lost three of the nodes. A few days later the other thermostat did the same thing and appeared as a single node. I removed them from isy and added them back. Each has four nodes again. So far so good. Very strange.
Has anyone had a smooth automatic upgrade from 2.7.0 to 2.7.15 with a MAC running Snow Leopard?
Michel,
Just to make it clear, you mention the dongle for the V2 thermostat. I have upgraded my thermo stat (ie the 2441), to V2, and now my ISY-99I reports the s/w as version v.91. Does that mean I have the dongle?
Mac updated to Snow Leopard 10.6.3 from Leopard 10.5.8 per email conversations with Michel.
Automatic update within the Admin Console fails due to the invalid length issue at 13%
Manual upgrade works when accessing the ISY through Safari using Https secure access with timeout set to 25000
Snow Leopard does indeed fix the myriad of issue I have experienced over the last year with Java compatibilities.
Small bug: When I minimize the admin console the icon that shows on the dock is the ugly house (which I hate) instead of the nice planet icon that is represented by the java application.
All seems well. $29 operating system upgrade money well spent.
