Program help please!
Have written tons of programs but this is getting me...
Issue:  I have a patio overhead door that I'd like to have automatically close at certain temp and open at certain temp. I made two programs to set a variable to cold  $sPatioGarageDoor=1   or warm $sPatioGarageDoor=2  and use these in my program to open or close the door.Here is the close program. (PatioGD Relay YL is my use of Yolink to control door over MyQ. Works great!)
Patio Garage Door Therm Close - [ID 0028][Parent 0001]
        $sPatio_garage_door is 1
    And 'Patio Garage Door YL' Door State is open
        Set 'Patio GD Relay YL' ON command
        Wait  5 seconds
        Set 'Patio GD Relay YL' OFF command
My issue is that if I want to let the dog out for some business when it's cold out the door opens and the close program shuts it immediately. I've written a few programs to try and get around it but need help...........
Thanks!!
Edited by drprm1
Solved by gzahar
One option: Is there a keypad nearby with an extra key? Pressing it could change another variable for the "business" at that time and override for x minutes
Another option: is "business" at known time windows? Program exceptions for those times
You need to create an integer variable the represents the state of the door.  Update this variable based on YL Door State (in separate program).
Use this variable in the IF statement of your open and close programs and not the direct YL Door State.
Edited by gzahar
Use this variable in your open and close programs.
Was thinking about that. Why would that work?
Because when you open and close the door manually it updates the integer variable which will not trigger your open and close programs.  Obviously you will need to manually close the door after you have opened it (and vice versa).  Your auto open and close programs will only trigger based on the temperature state variable changes.
Edited by gzahar
no keypad available...
Tried this for a business window of 5 min but it would never change the variable back to 1
        $sPatio_garage_door  = 0
        Wait  5 seconds
        Wait  5 minutes and 20 seconds
        $sPatio_garage_door  = 1
Because when you open and close the door manually it updates the integer variable which will not trigger you open and close programs.  Obviously you will need to manually close the door after you have opened it (and vice versa).  Your auto open and close programs will only trigger based on the temperature state variable changes.
I'll try this
