Setting to monaural?
Curious, is there the ability to set the audioplayer to Mono mode for output into an existing paging system, even if the source mp3 is stereo?  I have other methods to achieve the end result I'd like, Mono audio isn't exactly high tech, but if there happens to be some buried setting, that seems much the simplest.
Edited by jec6613
At the moment I don't see any setting capability to adjust the audio like balance, tone, volume, mono etc. At this time I will be using it just for voice announcements. Right now I will be connecting it to an audio mixer along with an ELK, Echo and phone system for paging into a russound system. Allows great flexibility. I do think that an audio combiner would work. Y-cable.  I made my own that includes resistors that isolate the channels to prevent interference with one another. However my mp3 announcing files are mono anyway so either channel alone should work.
Edited by garybixler
I actually have a couple commercially made combiners, I use one to tie in a subwoofer where I only have RCA stereo output, it's quite handy.
But yeah, I was just going to remix any MP3's I want into mono if there's no setting.  Mine is a Niles system, so similar idea, and I'll probably end up with a Russound system in the next couple of years since the Niles is about 8 years old and discontinued.
