Could not read config file
Hey folks, I am getting this error when trying to remove a button or Insteon sensor from a scene.  Essentially, it fails.  I am not sure what to do at this point.
firmwre: iox v5.8.0
Ui : same as above
Solved by rskirch
It appears that your scene may be corrupted.
Try deleting the scene and then recreate it, adding only the devices you want in the scene
Let me know if that resolves it.
That worked. I am not sure why I thought I had to remove the devices before I could delete the scene.  Thank you.
I spoke too soon.  Now I am trying to add the button to another scene and am getting the same named file error.
@rskirch
The link tables from the scene may still reside in the devices that were in the scene. As @tazman suggested, do a factory reset on the device(s) that were in the scene, then a restore device(s).
  • 3 months later...
I know it has been a while, but I finally dealt with this.  The devices wasn't being used so removed it from the EISY and then reset it.  Things are fine now.
