Remotetec ZRC-90
I had purchased a Polisy before the Eisy came out. I have since purchased a Eisy for use at my home, but I am using the Polisy while I can (until the Eisy is back in stock) at my office to replace the ISY994 I had there.  The process of switching from ISY994 to Polisy was fairly trouble free except for this:
  I have had a Remotetec ZRC-90 that has been working perfectly with the ISY, but does not work with the Polisy.  I excluded it and included it back, but is only adding 2 nodes (Controller and Wake-up).  None of the 8 scene buttons are showing up as scene controllers like they did in the ISY.  My Polisy is on 5.8.0
I'm not sure how popular this little ZRC-90 is, but it has worked flawlessly for 5 years or so.  If not, is there another scene controller (battery powered) that is tested with the Polisy?
Edited by rg65
added firmware version
Solved by rg65
Yes, it has a Z-Matter installed in it and zwave is enabled (Zigbee and Insteon are disabled).  There are about 25 other zwave devices that all work properly.
Edited by rg65
Cause
For future reference-the above posted solution to a different device also solved this problem.
