Configuring eisy to boot from an NVMe SSD - Partition 2 label name
What is the partition label name for the main partition (nvd0p2)?
I had a few issues doing the NVMe upgrade. The original script did not want to run with the two functions in it:  "setup_nvme_boot()" & "remove_emmc_mirror". So I broke the original script it into two separate scripts. That worked.
However these seems to be a missing third function: "update_efi_boot_loader_label". I would assume it relabels paration 2.
If someone could run "gpart list" on a factory system and provide the label name that would be great.
My current partition labels:
nvd0p1: efi
nvd0p2: (null)
nvd0p3: swap0
nvd0p4: HAIO
Also I made minor changes to the script.
added the alignment option and change the reserved size to 96 gb.
 MAIN_SIZE=`gpart show nvd0 | grep GPT | awk '{printf ("%.0f\n", ($3-42)/(2*1024*1024)-96)}'`
 gpart add -s ${MAIN_SIZE}G -t freebsd-zfs -a 512 nvd0
Added a 4th partition, by hand for home assistant.
 --> The eisy is a much more versatile box than i thought. Nice job team UD.
