Ecobee stopped working, on upgrade, and errors in log
I think I upgraded Ecobee to 3.1.5 and to stopped updating.
I clicked re-install and no love.
I uninstalled, rebooted eisy, and reinstalled still no love.
It has been running fine since Jan 2023.
I get this continually in the Ecobee log.
2024-02-11 13:21:22,602 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30
2024-02-11 13:21:22,603 MainThread udi_interface INFO __init__:<module>: UDI interface initializing
2024-02-11 13:21:22,603 MainThread udi_interface INFO __init__:<module>: User=0021b90262b6_3
2024-02-11 13:21:22,603 MainThread udi_interface INFO __init__:<module>: Home=/var/polyglot/pg3/ns/0021b90262b6_3
2024-02-11 13:21:22,603 MainThread udi_interface INFO __init__:<module>: Node Server Path=/var/polyglot/pg3/ns/0021b90262b6_3
2024-02-11 13:21:22,603 MainThread udi_interface INFO __init__:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MjE6Yjk6MDI6NjI6YjYiLCJwcm9maWxlTnVtIjozLCJsb2dMZXZlbCI6IldBUk5JTkciLCJ0b2tlbiI6IjNLciZ2dTBncEZBKEt5bHMiLCJtcXR0SG9zdCI6ImxvY2FsaG9zdCIsIm1xdHRQb3J0Ijo4ODgzLCJzZWN1cmUiOjEsImlzUEczeCI6dHJ1ZSwicGczVmVyc2lvbiI6IjMuMi4xOCIsImlzeVZlcnNpb24iOiI1LjguMCIsImVkaXRpb24iOiJTdGFuZGFyZCJ9
2024-02-11 13:21:22,603 MainThread udi_interface INFO __init__:<module>: Loading interface module
2024-02-11 13:21:22,649 MainThread udi_interface INFO interface:<module>: Loading MQTT module
2024-02-11 13:21:23,186 MainThread udi_interface INFO interface:<module>: MQTT module loaded
2024-02-11 13:21:23,424 MainThread udi_interface INFO __init__:<module>: Loading udi_interface module
2024-02-11 13:21:23,424 MainThread udi_interface INFO __init__:<module>: Loading node module
2024-02-11 13:21:23,425 MainThread udi_interface INFO __init__:<module>: Loading custom module
2024-02-11 13:21:23,425 MainThread udi_interface INFO __init__:<module>: Loading isy module
2024-02-11 13:21:23,425 MainThread udi_interface INFO __init__:<module>: UDI interface initialized
2024-02-11 13:21:23,425 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.2.6 Starting...
2024-02-11 13:21:23,429 MainThread udi_interface ERROR ecobee-poly:<module>: Excption: Unsupported callback API version: version 2.0 added a callback_api_version, see migrations.md for details
Traceback (most recent call last):
File "/var/polyglot/pg3/ns/0021b90262b6_3/ecobee-poly.py", line 11, in <module>
polyglot = Interface([Controller])
File "/var/polyglot/pg3/ns/0021b90262b6_3/.local/lib/python3.9/site-packages/udi_interface/interface.py", line 253, in __init__
self._mqttc = mqtt.Client(self.id, True)
File "/var/polyglot/pg3/ns/0021b90262b6_3/.local/lib/python3.9/site-packages/paho/mqtt/client.py", line 766, in __init__
raise ValueError(
ValueError: Unsupported callback API version: version 2.0 added a callback_api_version, see migrations.md for details
Solved by paulbates
Unfortunately you are the victim of bad timing. On of the underlying pg3x support libraries changed (MQTT) and caused  new installs of of plugins to break. I see MQTT error messages in your error log above.
UDI will work to restore it tomorrow, read this thread
Thanks for the info, I thought I was going crazy, I couldn't find much info on it. 👍
Thanks, just did the upgrade, and re-did PIN auth and presto changeo, it is back working!
Cheers
