I’ve got my Elk system, now I need help getting it connected…
someguy
I’ve got my Elk M1 Gold system up and running, now I need help getting it connected to my phone and my PolISY.
1) phone app:  I see four apps that seem like they will work. They all are called “ekeypad “. One even costs $140.  (I’ve never seen a that costs more than $20.)
are there other apps?  What do you guys recommend for an app that doesn’t have  recurring fees?
also:
to connect the Elk Nodeserver to the Elk, is it as simple as having a login to the Elk-RP2 system and using that to log in to the PG3?
Thank you.
also:
Thank you.
Once the plugin is setup and connected, UD Mobile will allow you to arm/disarm and monitor your Elk. You don't need another app.
Here are the directions for installing and using the Elk plugin:
https://github.com/UniversalDevicesInc-PG3/udi-poly-ELK/blob/master/README.md
When you setup the plugin, create a dedicated Elk user code for the plugin. You can not have the plugin and Elk-RP2 connected at the same time. They both use the non secure port to communicate.
      376.7k
