Support thread for: PG3x v3.2.19 (February 26th, 2024)
Hello everyone,
This is the support thread for PG3x v3.2.19.
If you are using the Backup or ELK plugin, please make sure to select the "Allow ISY Access By Plugin" in the configuration page.
Hello @bmercier, question. I am running Nodelink on eISY which is not a plug in on PG3 but I believe it uses Rest. Is the Rest API warning only for PG3 plug ins or anything that uses Rest to communicate with eISY?
-Tim
-Tim
This applies to plugins that want to make rest requests.
Other apps can still use rest requests the same way as before.
Hi @bmercier,  Upgrade went well except for ST-Inventory threw a lot of messages in UD Mobile, saying it was connected. However no data is populated in the AC. All other plugins are working fine for me.
Nodelink continues to work well on eISY after update thankfully.
I have sent you a pm with logs.
@TJF1960@macjeff Looks like this plugin needs access to the rest API.
The author needs to edit his store entry and check "Require ISY Access". Then, in the configuration page, PG3x will display the "Allow ISY Access" checkbox.
Not sure who the author is, and if this plugin is still maintained.
I think @bpwwer   did it last time since Simplextech is no longer doing it (heard that from UD staff).   I will drop Bob a message
Jeff
Edited by macjeff
ST Inventory has been updated and is working now.  I had to UNINSTALL and REINSTALL as it would not update.
  • Thanks 1
what version of ST-Inventory do you have as the latest? Am at v1.0.12 and don't have a message to upgrade but the change log for this latest version doesn't date the change or link it to this issue.
Quote
v1.0.12 Fix typo in mqtt close
Oops, I should have posted this in the ST-Inventory forum. I pointed to the above in that forum so no need to answer here. I'm sure I'll get an answer over there.
they only added the option to click in CONFIG for direct access.
Version was NOT bumped but if you sort by date in PG3x Store you will see it was just released a day ago
Uninstall and then reinstall in the same slot.  Then you will still get errors but go into configuration and click the direct access checkbox.  Then restart and it works 100% for me.
      376.9k
