Hunter Douglas shade plugin version 0.1.3
A few refinements.  I re-wrote the discover routine so that it was smarter & didn't duplicate nodes for shades/scenes and also knew to delete ones it couldn't find.  If you get too verbose with your naming it is easy to use up the 30 characters ISY allows you, so I limited the room text to 15 chars, giving the balance to the shade/scene name.  Could make this a parameter or even more cool make the shades/scenes nodes children of the rooms.  In the background I have reduced some of the debug logging which I more needed during development.  Finally I have been having fun with a willing victim to develop G2 capabilities without breaking G3, thank you @GTenchfor your patience.  We now have nodes, and soon I am hoping movement for the G2 users.
Feedback is welcome!
VERSION = '0.1.3'
0.1.3
DONE node discover rewrite to allow add/remove
DONE add event 'homedoc-updated' currently no actions
DONE limit room label size to 15 as room - shade/scene < 30 for ISY
DONE clean up LOGGING.debug messages
FIXME G2 bug fixes
add to future version:
TODO bugfix & test
0.1.2
DONE change icons to nicer ones
DONE docs with screenshots & description for udi spotlight
DONE add troubleshooting document
DONE add some support for G2 gateways (no gateway push, only polling)
0.1.1
DONE tap into gateway events, which allows longPoll update to move from 30s to 60s
DONE active scene indications from events
DONE shade motion indicator from events
DONE shade position update from start, stop, online events
DONE remove parameters based on shade capability (primary, secondary, tilt)
DONE update readme & config instructions to highlight G3 scope
0.1.0
DONE handle multiple gateways automatically, picking primary & switching if required
DONE updated configuration instructions as well as link to the forums
past versions:
0.0.9
DONE fix uom for positions(100) & ids(107)
DONE more notices clean-up
DONE shade naming to include room as scenes
DONE remove status based on shade capability (primary, secondary, tilt)
0.0.8:
DONE handling of notices individually
DONE polling 5s short-poll 30s long-poll
DONE status for programs (positions etc)
0.0.7:
DONE faster status updates when command is given
DONE bug fix
DONE re-order of parameters displayed
0.0.6:
DONE move shade by specific amounts
DONE bug fix scenes not activating
0.0.5:
DONE change shortpoll to 30s
DONE update shades on shortpoll
DONE clear start notice at shortpoll
DONE clean up error proofing in get
DONE fix updating variables with shortpoll
DONE limit device ping to 5s
0.0.4:
DONE discover when new gatewayip is entered
DONE poll status regularly using shortpoll
DONE update required after nodes added to get status
DONE notice when gateway get error
