Storing program math results
Okay.... I am working on  program which will, each day, produce a mathematical result measured in terms of a variable (to be explicit, degree days, stored in an integer variable by the same name).
I would like to store those in a way that would let me later compile a total for a stated time period.. (again to be explicit from march 1 until a specified total number is reached.... basically from mar 1 until June 30)
Has anyone tackled something like this?
I am eyeing the TimeDate plug in as a part of the solution, but before I go searching for a champagne solution to a beer project thought I might solicit views on this problem.
Thank for looking and I solicit any and all thoughts...
Solved by larryllix
I did a few things like this by using a block of ISY memory locations and creating a shift register that operated each day on a schedule.
A lot of hardcoding in ISY since it has no indexing function but....something like this.
Program Shifter
if
     whatever
      set mem30 = mem29
      set mem29 = mem28
      set mem28 = mem27
      set mem1 = mem0
      set mem0 = Day.data
Esle
Data over 30 days old will be lost but last 30 days will be available for a summation.
Program total30
    ---whatever
      30dayTotal = mem30
      30dayTotla += mem29
      30dayTotla += mem28
      30dayTotal += mem0
      $s30dayTotal = 30dayTotal <--move to state variable for processing
Larry thanks. I suspected this would be a "brute force" solution kind of task. I had set up a weeks worth of defined integer variables for the test. Is something like that what you are referring to a block of memory locations?
Edited by glacier991
Yes.
I had requested some form of indexing variables, years ago, but other expansions got in the way.
Is there any numeric limit on the number of variables Eisy can have (and support)?
I doubt that a human, manually coding without some automatic indexing code could ever run into that limit. ISY comes with GigaBytes now.
  • Whew. That means I am safe, for now.😉
  • On another matter, I followed your suggestion for creating a monthly register. For the total I approached it a little differently. On a daily basis I add the current day value to a variable I call Cumulative DD. I increment a counter at the same time. When the counter reaches 30 (or 31 depending on the month) following that days addition I move the Cumulative DD value into a state variable. Ka-ching.. I just saved 29 variables from a fate worse than math.
  • Whew. That means I am safe, for now.[emoji6]
I don't like basing things on long timers. They tend to fail or crash or I stall them by editing.
I would just trigger a program to save the tally, and possibly ckeaout all the registers each 12:00:05 each first of the month.
Of course I keep my own date variables based on ISY's provided system variables so that is easy.
Definitely interested. Interestingly the Yolink thermometers keep their data for months or longer, and enable downloading it in comma delimited format for your stated date range. Not applicable in my situation, but interesting.
One of my program populates variables with 3 irrigation data points and then writes the data to a file in the IoX web server using a Notification. I believe there was a little setup on the web server but I can't find it right now.  Feels like it was just creating the location and the file within the web servers file structure,
Irrigation Program segment
        $Water_Today_Start_I  = 'Flume Water / FlumeWater / Flume Sensor 6811460334891002' Today US gallons
        Set 'Yard / Yard:Front Mulch Beds' On 100%
        Wait  Zone_1 minutes
        $Water_Today_End_I  = 'Flume Water / FlumeWater / Flume Sensor 6811460334891002' Today US gallons
        $Water_Today_Difference_I  = 0
        $Water_Today_Difference_I += $Water_Today_End_I
        $Water_Today_Difference_I -= $Water_Today_Start_I
        Send Notification to 'MeDataText' content 'Irrigation Log Data'
Irrigation Log Data Custom Notification
Subject :  @webpage:@append:/irrigate/irg_log.csv Irrigation
Body:       ${sys.program.#.name},${alert.date},${alert.time24},${var.1.42},${var.1.43},${var.1.44}
${var.1.42} etc
1=An Integer Variable
42=Integer Variable ID with the name Water_Today_Start_I
Edited by hart2hart
@hart2hart That's nice!
There is a reference in iox 5.8.0 in January to a SQLite database being added for node values, but IIFC it was more a future feature and no details provided.
If that were available I would love to store / access values in it, using a client on my pc.
So far it seems I spend my time trying to get data INTO EISY, now flipping the coin trying to figure out how to get data OUT of it !
Keeping the old brain young.
I vaguely recall SQLite but seems like it was not ready for prime time yet.
There is a way to post data to a Google Sheet.  I post data once per minute to a sheet.  I think there's a maximum # of rows one can post.  Therefore, I clear my sheet (automatically) at 2am.  I just want current data.  If you're only going to post once per day, you can certainly have a year's worth of data in there.
Interested, can you tell more about the ability to post to a "Google sheet? Getting data outside EISY where it can be otherwise used and manipulated seems possible, but elusive.
This sounds intriguing. So much so I am wondering is a separate topic addressing just that might be appropriate and welcomed! (From besides me.)
because of fat fingers
