PG3x migration
I've read all I can on the wiki and the forums.
I have an older Polisy running v13.0 (5.4.4 / PG3), so updates are not safely available with the Admin UI UPDATE button.
Getting updated means reflashing the mSATA card (I'm familiar, already done once), but on a working Polisy that can lead to a number of challenges.
Specifically here, if someone could answer about the PG3 -> PG3x issue.
Should I update to PG3x now, it does indicate to not do that unless you updated your device, which I can't do directly, so assuming I shouldn't.
Backing up PG3, can that be restored to the PG3 running on the new flashed mSATA, which will have 5.8.0 and the last available PG3, or should I then update the PG3 -> PG3x first, before trying a restore?
* Orest
Edited by oskrypuch
I have been told by @Michel Kohanim, that the optimal sequence is to enable PG3x on the reflashed Polisy, and only then to restore the old PG3 nodes.
* Orest
Edited by oskrypuch
