Can't Discover new Bond Bridge Pro
I've seen the instructions about adding the hostname and token custom parameters before trying to Discover, but I still can't get it to work.
I have a message:
"Unable to authenticate with the Bond bridge at hostname 192.168.1.73 using the supplied token. Please check the corresponding 'token' parameter value in the Custom Configuration Parameters and try Discover command again."
I couldn't find anything in the Bond app Settings about a "local access token", but I did find something called "Account Code" that is 16 digit hexdecimal, so I've been trying that, but it doesn't seem to be the right thing as it doesn't work.
Solved by atmarosi
In the bond app click on the bond pro under my bonds: see IMG910
At the bottom hit advanced: see IMG913
local token should be the second field: see IMG912
  • 4 weeks later...
