A few sensors not showing up properly in V1.0.6
I updated to V1.0.6 this afternoon and noticed a few of my sensors don't seem to be reflected as expected.  My Garage Door Controller (YS4906-UC) shows as "Not Connected" until I open or close the garage door, then it shows as "Connected".  My leak sensors (YS7903-UC) all show as "Not Connected" even though the Yolink app shows them as being online.  I haven't tried to manually trigger them, but can do that if it would help.  I'm also happy to send you logs if needed.
Solved by Panda88
If you can send a log - with debug I can try to see what is going on - It may be in needs to wait until first poll - Garage controller is trick as you cannot poll it
What variable are you referring to - Online-Offline/suspended is GV20
ST is supposed to show connection to ISY - I think I did default it to no-connected until first transaction
The leak sensor (first one) seems to show GV20 = 0 - so connected - 1 is suspended due to too many calls and 2 is offline
These are the four devices that show up as being "Not Connected" in the easy admin console, but the Yolink app all shows them as being in a "Normal" state.
I fixed the garage door controller to show connected (even if it was not activated)
I also found that I somehow had commented out the connection change in the leak sensor (it was the one I used for main development) - it is also fixed
1.0.7 is coming soon
Awesome - thanks!  And thanks for the ongoing work on the Yolink node server.  It's worked really well in my environment, and the reliability, range, and integration of the devices in eisy is great.
It is always difficult to handle connection when there are multiple connections - one is from node to ISY - the other is node to YoLink API
I have used ST (shown above to show connection to ISY
I have used GV20 to show connection state to Yolink API
I believe the leak sensor should be fixed in 1.0.7
