Michel Kohanim Posted March 29 Posted March 29 Hello everyone, This plugin is a very simple plugin that allows you to import your own YouTube playlists and play them through eisy. IMPORTANT: Since this plugin is still in beta, please send your email address (the one you use to login to your YouTube account) to support@universal-devices.com and request to be added to the beta list. Instructions: Upon successful installation, click on the Authorization button in PG3 page for this plugin. This is a secure authorization process through Google such that neither UD nor eisy need to capture your credentials. Once the authorization is successful, please restart the Admin Console and you should be able to see your playlists. If playlist is empty or not complete, please restart the Admin Console. For Bluetooth, you need the Bluetooth plugin. With kind regards, Michel 1
Whitehambone Posted April 3 Posted April 3 @Michel Kohanim I have been testing this plugin. I start a playlist with the speaker jack output. After the first song, nothing changes in the AC, but the audio switches to bluetooth. Starting with bluetooth, it stays with bluetooth.
Michel Kohanim Posted April 3 Author Posted April 3 @Whitehambone, most probably because something else is changing it to bluetooth. In short, the output does not change automatically. Can you please check the logs? With kind regards, Michel
Whitehambone Posted April 3 Posted April 3 @Michel Kohanim This is repeatable. Around 3:31, I switched to the speaker jack and started to play, and as the first song ended, the AC went from Playing to Idle momentary. Then it started to play to the Bluetooth again. It happens after the first song. This is the log from the AC: Nodes / YouTube Player Custom Control 2 Speaker Jack Wed 2024/04/03 03:31:30 PM System Unknown Nodes / YouTube Player Status Playing Wed 2024/04/03 03:31:36 PM System Unknown Nodes / YouTube Player Custom Control 0 3 Wed 2024/04/03 03:31:37 PM System Unknown Nodes / YouTube Player Status Idle Wed 2024/04/03 03:35:05 PM System Unknown Nodes / YouTube Player Custom Control 0 None Wed 2024/04/03 03:35:05 PM System Unknown Nodes / YouTube Player Status Playing Wed 2024/04/03 03:35:08 PM System Unknown Nodes / YouTube Player Custom Control 0 3 Wed 2024/04/03 03:35:08 PM System Unknown Nodes / YouTube Player Status Idle Wed 2024/04/03 03:35:20 PM System Unknown Nodes / YouTube Player Custom Control 0 None Wed 2024/04/03 03:35:20 PM System Unknown This is from PG3: 2024-04-03 15:31:30,610 Command udi_interface INFO audio_player:processCommand: Got command: {'address': 'ytsvc', 'cmd': 'OUTPUT', 'value': '0', 'uom': '25', 'query': {}} 2024-04-03 15:31:30,681 MQTT udi_interface.interface INFO interface:_message: Successfully set ytsvc :: GV2 to 0 UOM 25 2024-04-03 15:31:36,949 Command udi_interface INFO audio_player:processCommand: Got command: {'address': 'ytsvc', 'cmd': 'PLAY', 'value': '3', 'uom': '25', 'query': {}} 2024-04-03 15:31:36,949 Command udi_interface INFO audio_player:processCommand: Playing #3:./playlists/Mix.m3u 2024-04-03 15:31:36,993 MQTT udi_interface.interface INFO interface:_message: Successfully set ytsvc :: ST to 1 UOM 25 2024-04-03 15:31:37,072 MQTT udi_interface.interface INFO interface:_message: Successfully set ytsvc :: GV0 to 3 UOM 25 2024-04-03 15:31:37,114 MQTT udi_interface.interface INFO interface:_message: Successfully set ytsvc :: GV3 to 30 UOM 51 2024-04-03 15:35:05,821 MQTT udi_interface.interface INFO interface:_message: Successfully set ytsvc :: ST to 0 UOM 25 2024-04-03 15:35:05,862 MQTT udi_interface.interface INFO interface:_message: Successfully set ytsvc :: GV0 to 0 UOM 25 2024-04-03 15:35:08,036 MQTT udi_interface.interface INFO interface:_message: Successfully set ytsvc :: ST to 1 UOM 25 2024-04-03 15:35:08,077 MQTT udi_interface.interface INFO interface:_message: Successfully set ytsvc :: GV0 to 3 UOM 25 2024-04-03 15:35:20,026 Command udi_interface INFO audio_player:processCommand: Got command: {'address': 'ytsvc', 'cmd': 'STOP', 'query': {}} 2024-04-03 15:35:20,080 MQTT udi_interface.interface INFO interface:_message: Successfully set ytsvc :: ST to 0 UOM 25 2024-04-03 15:35:20,119 MQTT udi_interface.interface INFO interface:_message: Successfully set ytsvc :: GV0 to 0 UOM 25
Michel Kohanim Posted April 3 Author Posted April 3 @Whitehambone, Fixed. Please upgrade to 1.0.3. With kind regards, Michel 1 1
TJF1960 Posted April 5 Posted April 5 Installation was straightforward and easy. After about 5 minutes or so the playlist from YouTube was available for streaming. Very cool! I am enjoying it. Thank you @Michel Kohanim -Tim
