YouTube Plugin Version 1.0.2 - Beta
Hello everyone,
This plugin is a very simple plugin that allows you to import your own YouTube playlists and play them through eisy.
IMPORTANT:
Since this plugin is still in beta, please send your email address (the one you use to login to your YouTube account) to support@universal-devices.com and request to be added to the beta list.
Instructions:
Upon successful installation, click on the Authorization button in PG3 page for this plugin. This is a secure authorization process through Google such that neither UD nor eisy need to capture your credentials.
Once the authorization is successful, please restart the Admin Console and you should be able to see your playlists. If playlist is empty or not complete, please restart the Admin Console.
For Bluetooth, you need the Bluetooth plugin.
@Michel Kohanim I have been testing this plugin.  I start a playlist with the speaker jack output.  After the first song, nothing changes in the AC, but the audio switches to bluetooth.  Starting with bluetooth, it stays with bluetooth.
@Michel Kohanim This is repeatable.  Around 3:31, I switched to the speaker jack and started to play, and as the first song ended, the AC went from Playing to Idle momentary.  Then it started to play to the Bluetooth again.  It happens after the first song.
This is the log from the AC:
Nodes / YouTube Player	Custom Control 2	Speaker Jack	Wed 2024/04/03 03:31:30 PM	System	Unknown
Nodes / YouTube Player	Status	Playing	Wed 2024/04/03 03:31:36 PM	System	Unknown
Nodes / YouTube Player	Custom Control 0	3	Wed 2024/04/03 03:31:37 PM	System	Unknown
Nodes / YouTube Player	Status	Idle	Wed 2024/04/03 03:35:05 PM	System	Unknown
Nodes / YouTube Player	Custom Control 0	None	Wed 2024/04/03 03:35:05 PM	System	Unknown
Nodes / YouTube Player	Status	Playing	Wed 2024/04/03 03:35:08 PM	System	Unknown
Nodes / YouTube Player	Custom Control 0	3	Wed 2024/04/03 03:35:08 PM	System	Unknown
Nodes / YouTube Player	Status	Idle	Wed 2024/04/03 03:35:20 PM	System	Unknown
Nodes / YouTube Player	Custom Control 0	None	Wed 2024/04/03 03:35:20 PM	System	Unknown
This is from PG3:
2024-04-03 15:31:30,610 Command    udi_interface      INFO     audio_player:processCommand: Got command: {'address': 'ytsvc', 'cmd': 'OUTPUT', 'value': '0', 'uom': '25', 'query': {}}
2024-04-03 15:31:30,681 MQTT       udi_interface.interface INFO     interface:_message: Successfully set ytsvc :: GV2 to 0 UOM 25
2024-04-03 15:31:36,949 Command    udi_interface      INFO     audio_player:processCommand: Got command: {'address': 'ytsvc', 'cmd': 'PLAY', 'value': '3', 'uom': '25', 'query': {}}
2024-04-03 15:31:36,949 Command    udi_interface      INFO     audio_player:processCommand: Playing #3:./playlists/Mix.m3u
2024-04-03 15:31:36,993 MQTT       udi_interface.interface INFO     interface:_message: Successfully set ytsvc :: ST to 1 UOM 25
2024-04-03 15:31:37,072 MQTT       udi_interface.interface INFO     interface:_message: Successfully set ytsvc :: GV0 to 3 UOM 25
2024-04-03 15:31:37,114 MQTT       udi_interface.interface INFO     interface:_message: Successfully set ytsvc :: GV3 to 30 UOM 51
2024-04-03 15:35:05,821 MQTT       udi_interface.interface INFO     interface:_message: Successfully set ytsvc :: ST to 0 UOM 25
2024-04-03 15:35:05,862 MQTT       udi_interface.interface INFO     interface:_message: Successfully set ytsvc :: GV0 to 0 UOM 25
2024-04-03 15:35:08,036 MQTT       udi_interface.interface INFO     interface:_message: Successfully set ytsvc :: ST to 1 UOM 25
2024-04-03 15:35:08,077 MQTT       udi_interface.interface INFO     interface:_message: Successfully set ytsvc :: GV0 to 3 UOM 25
2024-04-03 15:35:20,026 Command    udi_interface      INFO     audio_player:processCommand: Got command: {'address': 'ytsvc', 'cmd': 'STOP', 'query': {}}
2024-04-03 15:35:20,080 MQTT       udi_interface.interface INFO     interface:_message: Successfully set ytsvc :: ST to 0 UOM 25
2024-04-03 15:35:20,119 MQTT       udi_interface.interface INFO     interface:_message: Successfully set ytsvc :: GV0 to 0 UOM 25
