error: NS: uncaughtException REPORT THIS!: ReferenceError: finduuid is not defined
Found the following in my logs while researching something else. Thought I would report it as instructed.
Quote
2024-04-07 10:12:20 error: NS: uncaughtException REPORT THIS!: ReferenceError: finduuid is not defined
Here are log entries from just before and after the error:
2024-04-07 10:12:20 info: NS: Player Volume: 44
2024-04-07 10:12:20 info: NS: Group Volume: 44
2024-04-07 10:12:20 info: POLY: Setting node 8326214 driver GV1: 44
    at /var/polyglot/pg3/ns/<myISYMACaddr>d_3/node_modules/sonos-discovery/lib/prototypes/Player/recalculateGroupVolume.js:7:9
    at Array.find (<anonymous>)
    at /var/polyglot/pg3/ns/<myISYMACaddr>d_3/node_modules/sonos-discovery/lib/prototypes/Player/recalculateGroupVolume.js:6:24
    at Player.recalculateGroupVolume (/var/polyglot/pg3/ns/<myISYMACaddr>d_3/node_modules/sonos-discovery/lib/prototypes/Player/recalculateGroupVolume.js:5:30)
    at NotificationListener.notificationHandler (/var/polyglot/pg3/ns/<myISYMACaddr>d_3/node_modules/sonos-discovery/lib/models/Player.js:370:25)
    at NotificationListener.emit (node:events:529:35)
    at /var/polyglot/pg3/ns/<myISYMACaddr>d_3/node_modules/sonos-discovery/lib/NotificationListener.js:125:17
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2024-04-07 10:12:20 error: POLY: uncaughtException: finduuid is not defined
2024-04-07 10:12:20 error: NS: uncaughtException: finduuid is not defined
2024-04-07 10:12:24 info: NS: Starting Node Server
2024-04-07 10:12:24 info: POLY: Interface starting
2024-04-07 10:12:24 info: POLY: Getting config from environment
2024-04-07 10:12:24 info: POLY: MQTT client connected
2024-04-07 10:12:24 info: NS: MQTT Connection started
2024-04-07 10:12:24 error: POLY: Config has logLevel: INFO
2024-04-07 10:12:24 info: POLY: Loglevel: info
2024-04-07 10:12:24 info: NS: Config received has 7 nodes
2024-04-07 10:12:24 info: POLY: Setting node a980b70 driver GV0: 0
2024-04-07 10:12:24 info: POLY: Setting node a980b70 driver GV1: 0
2024-04-07 10:12:24 info: POLY: Setting node a980b70 driver GV7: 0
2024-04-07 10:12:24 info: POLY: Setting node a980b70 driver GV8: 0
2024-04-07 10:12:24 info: POLY: Setting node 8326214 driver GV0: 0
2024-04-07 10:12:24 info: POLY: Setting node 8326214 driver GV1: 0
2024-04-07 10:12:24 info: POLY: Setting node 8d9e68c driver GV0: 0
2024-04-07 10:12:24 info: POLY: Setting node 8d9e68c driver GV1: 0
2024-04-07 10:12:24 info: POLY: Setting node a980b70 driver GV0: 22
2024-04-07 10:12:24 info: POLY: Setting node 8d9e68c driver GV0: 50
2024-04-07 10:12:24 info: POLY: Setting node 831736c driver GV0: 0
2024-04-07 10:12:24 info: POLY: Setting node 831736c driver GV1: 0
2024-04-07 10:12:24 info: POLY: Setting node 831736c driver GV7: 0
2024-04-07 10:12:24 info: POLY: Setting node 831736c driver GV0: 50
2024-04-07 10:12:24 info: POLY: Setting node 75cc226 driver GV0: 0
2024-04-07 10:12:24 info: POLY: Setting node 75cc226 driver GV1: 0
2024-04-07 10:12:24 info: POLY: Setting node 8326214 driver GV0: 44
2024-04-07 10:12:25 info: POLY: Setting node 75cc226 driver GV0: 35
2024-04-07 10:12:29 info: NS: Discovering
2024-04-07 10:12:29 info: NS: Zone Coordinator: RINCON_B8E9377949FD01400 - Room TV Room
2024-04-07 10:12:29 info: NS: Members UUID: RINCON_B8E9377949FD01400, - Room: TV Room
2024-04-07 10:12:31 info: NS: Zone Coordinator: RINCON_7828CA980B7001400 - Room Portable 2
2024-04-07 10:12:31 info: NS: Members UUID: RINCON_7828CA980B7001400, - Room: Portable 2
2024-04-07 10:12:32 info: NS: Zone Coordinator: RINCON_000E58D9E68C01400 - Room Dining Room
2024-04-07 10:12:32 info: NS: Members UUID: RINCON_000E58D9E68C01400, - Room: Dining Room
2024-04-07 10:12:33 info: NS: Zone Coordinator: RINCON_000E5831736C01400 - Room Kitchen
2024-04-07 10:12:33 info: NS: Members UUID: RINCON_000E5831736C01400, - Room: Kitchen
2024-04-07 10:12:34 info: NS: Zone Coordinator: RINCON_B8E9375CC22601400 - Room Portable
2024-04-07 10:12:34 info: NS: Members UUID: RINCON_B8E9375CC22601400, - Room: Portable
2024-04-07 10:12:35 info: NS: Zone Coordinator: RINCON_000E5832621401400 - Room Rec Rm-Workshop
2024-04-07 10:12:35 info: NS: Members UUID: RINCON_000E5832621401400, - Room: Rec Rm-Workshop
