Home Assistant VM on eisy Error - Unsupported system - virtualization_image
Setup Home assistant VM a few weeks ago following these instructions: https://developer.isy.io/blog/Home Assistant
Did updates yesterday to Home Assistant and am now getting an "Unsupported system - virtualization_image" error.
Screen capture below and HA information on this error here: https://www.home-assistant.io/more-info/unsupported/virtualization_image
HA state solution is to reinstall Home Assistant OS using an image which supports being run on a virtualized system.
Will this be supported on the eisy?
I got that initially, but I tried again later and it worked fine. I'm not sure what changed.
Maybe it was fixed with 2024.4.2, which came out yesterday, but maybe after my first attempt and before my second?
Edited by stevesreed
I'm running 2024.4.2 and have the error. Did a restart of HA and error remains.
The error is legit, but it is just a warning. The script on the blog uses the generic x64 OS image instead of one of the VM tailored images. They don’t have a FreeBSD VM image specifically but when I have some time I’ll see if I can get one of the other VM images running instead.
For now it should be reasonably safe to ignore.
Thanks for the insight on the image used in the script. I've done 3-4 updates and the error just now displayed.
  • 3 weeks later...
I finally had a few cycles to take a look at this.  I wrote up a modified script that will use the VM based Home Assistant images instead of the one meant for bare metal.  I also added some other tweaks that allow you to choose to enable access to the VM via console, VNC, and SSH during install.  Unfortunately there isn't an easy way to "fix" an existing install so you'll need to start from scratch or you can try backing up and restoring your HA config but no guarantees there.
To start this will delete your current VM and all related configs.  It will completely destroy your existing Home Assistant VM so only run this if you want to start fresh or are sure you have all the backups you need.
sudo vm poweroff -f homeassistant
sudo vm destroy -f homeassistant
sudo vm switch destroy public
sudo zfs destroy storage/vms
Here is a new create_ha_vm.sh script.  Save it and run it with sudo.
see updated version below
@Michel Kohanim it might be worth updating the blog post with this script so new installs get the proper image.
Edited by apnar
removed script as updated posted
@apnarI ran your script and it seemed like it ran fine except for an error on line 126 which I think should not affect HA. It shows like homeassistant VM is running but homeassistant.local:88123 does not come online at all and not even showing up in my router with an IP address. If I go to the VNC address it has a shell prompt but if I back out of that it seems like it is the Bhyve loader and I think HA is crashing but can not find any proof of that. I was able to rerun my old script an load the old HA again with no problem.
@tazman thanks for giving it a try.  Took me a bit but I tracked down the issue.  I use a significantly bigger sized virtual disk in my setup but had dropped it down to 16GB when I uploaded it to match what was in the original script.  Even though the OVA file from HA is only 800MB they have it configured as a 32GB virtual disk so when it was trying to be copied to the smaller 16GB volume it errored out.  Guess that's what I get for thinking a small tweak wouldn't cause any issues.
As to the error on line 126, I'm not seeing that but suspect it might be related to posting the shell script on the forum.  So I added some extra quoting and I'll upload it as a file here in addition to pasting it.
Updated version:
#!/bin/sh
# Where do we want to storge VM resources (ZFS pool name and mount path)
VMFILESET="storage/vms"
VMDIR="/storage/vms"
# Home Assistant VM name and how much resources to allocate
HA_VM_NAME="homeassistant"
HA_VM_CPU="2"
HA_VM_MEM="1G"
HA_VM_DISC="32G"
# specify network interface - by default it's Ethernet re0
INTERFACE="re0"
if [ $(id -u) != "0" ]
  then echo "Must be run with sudo"
  exit
fi
# Automatically pick the latest release from https://github.com/home-assistant/operating-system/releases/
HA_IMAGE_URL=$(curl -sL https://api.github.com/repos/home-assistant/operating-system/releases/latest | \
	grep "browser_download_url.*haos_ova.*qcow2.xz" | sed -e 's/.*: "\(.*\)"/\1/')
# Internal variables
TMPDIR=`mktemp -d`
IMAGE_NAME="${TMPDIR}/haos_ova-x86-64.img"
VM_CONF=${VMDIR}/${HA_VM_NAME}/${HA_VM_NAME}.conf
# make sure ifconfig_DEFAULT is not set as it causes tap0 interface issues
# ensure re0 is set to DHCP
sysrc -x ifconfig_DEFAULT
sysrc ifconfig_re0="DHCP"
echo "Make sure necessary packages are installed"
pkg install -y vm-bhyve edk2-bhyve wget qemu-tools
echo "Prepare /etc/rc.conf"
sysrc vm_enable="YES"
sysrc vm_dir="zfs:${VMFILESET}"
# this makes Home Assistant VM start up automatically on boot, comment out if this is not desired
sysrc vm_list=${HA_VM_NAME}
echo "Create ZFS fileset for VMs and prepare templates"
zfs create ${VMFILESET}
vm init
cp /usr/local/share/examples/vm-bhyve/*.conf ${VMDIR}/.templates/
# create VM networking (common for all VMs on the system)
vm switch create public
vm switch add public ${INTERFACE}
echo "Downloading image"
wget -O ${IMAGE_NAME}.xz ${HA_IMAGE_URL}
echo "Extracting..."
unxz ${IMAGE_NAME}.xz
echo "Creating a VM"
vm create -t linux-zvol -s ${HA_VM_DISC} ${HA_VM_NAME}
echo "Image info:"
qemu-img info ${IMAGE_NAME}
echo
echo "Copying image... (may take a bit of time)"
qemu-img convert ${IMAGE_NAME} /dev/zvol/${VMFILESET}/${HA_VM_NAME}/disk0
rm -rf ${TMPDIR}
GRAPHICS=0
echo -e "\n\nDo you want to enable unauthenticated VNC access to your Home Assistant virtual machine? (y/N)"
read answer
if [ "$answer" = "Y" ] || [ "$answer" = "y" ]
then
  GRAPHICS=1
  sysrc -f ${VM_CONF} graphics="yes"
fi
## Initial setup
TMPDIR=`mktemp -d`
# set zvol to full so partitions are visable
zfs set volmode=full ${VMFILESET}/${HA_VM_NAME}/disk0
sleep 2
# set baud rate for serial console
mount -t msdosfs /dev/zvol/${VMFILESET}/${HA_VM_NAME}/disk0p1 ${TMPDIR}
# add serial console to linux boot command line
sed -i '' -e 's/console=ttyS0/console=ttyS0,115200/' ${TMPDIR}/cmdline.txt
# umount device
umount ${TMPDIR}
SSH=0
echo -e "\n\nDo you want to enable SSH access to your Home Assistant virtual machine? (y/N)"
read answer
then
  SSH=1
  ## SSH Access
  # install ext4 fuse driver and load it
  pkg install -y fusefs-lkl
  kldload fusefs
  # mount vms /root/.ssh directory
  lklfuse -o type=ext4 /dev/zvol/${VMFILESET}/${HA_VM_NAME}/disk0p7 ${TMPDIR}
  sleep 5
  mkdir -p ${TMPDIR}/root/.ssh
  chmod 700 ${TMPDIR}/root
  chmod 755 ${TMPDIR}/root/.ssh
  # create a new SSH keypair and at it as an authorized key in the VM
  ssh-keygen -t ed25519 -N "" -C "Access Home Assistant running on eisy on port 22222" -f /home/admin/ha-ssh-key
  cp /home/admin/ha-ssh-key.pub ${TMPDIR}/root/.ssh/authorized_keys
  # set perms so admin user can access the ssh keys
  chown admin:admin /home/admin/ha-ssh-key*
  umount ${TMPDIR}
fi
## Clean up
# switch zvol mode back to normal
zfs set volmode=dev ${VMFILESET}/${HA_VM_NAME}/disk0
sleep 5
rmdir ${TMPDIR}
sysrc -f ${VM_CONF} loader="uefi"
sysrc -f ${VM_CONF} cpu=${HA_VM_CPU}
sysrc -f ${VM_CONF} memory=${HA_VM_MEM}
vm start ${HA_VM_NAME}
vm info ${HA_VM_NAME}
vm list
echo -e "\n\n##########################################################################\n"
echo "Please wait about 10 minutes and follow instructions at https://www.home-assistant.io/getting-started/onboarding/ to get your Home Assistant setup"
echo "ISY integration: https://www.home-assistant.io/integrations/isy994/"
echo -e "\nIf you need console access to the HA VM you can run \"sudo vm console ${HA_VM_NAME}\" then log in is as root.  Use \"~~.\" to exit."
if [ "$GRAPHICS" -eq "1" ]; then
  echo -e "\nYou can access your HA VM via VNC on port 5900 at your eisy's IP address."
fi
if [ "$SSH" -eq "1" ]; then
  echo -e "\nYou can access your HA VM via SSH using \"ssh -p22222 -i ha-ssh-key root@{HA VM IP}\""
fi
md5 of script is 93f64d030f2531578df06c46d35c8056
create_ha_vm.sh
@apnar thanks for your work on this! I was giving mine 50G of space so that should not have been a problem for me. I will give it another try over the weekend.
@apnarthank you for your work on this! I downloaded the file and everything worked for me and I only change 2 lines
HA_VM_MEM="2G"
HA_VM_DISC="60G"
