program tab issue....
EWhite
Go to solution Solved by paulbates,
ok.. polisy with latest updates.
java all cleared on latest version.
Problem is in AC if i try to go to the programs tab, it just hangs on the "creating widgets" little window and then finally dies after about 10 minutes.
all other tabs are working just fine.
I can get to my programs through UD mobile...but not ideal.
I also tried bringing up the event viewer during all this and it also locks up, but no strange activity before trying to open programs tab.
ideas???
any help be much appreciated!
Since it programs can be accessed in UDM and working... to me it points to the java installation on the computer.  Do you have a lot of programs and variables. This is an older recommendation for t something that has the appearances of a memory problem
Java runtime memory (when Admin Console is very slow to respond)
-      If the admin console is slow to respond, it is likely you need to increase the amount of memory allocated to the Java runtime (JRE).
-      Open the Java Control Panel, select Java tab, press View button, then add or modify the Runtime Parameter -Xmx to the following:
o   -Xmx512m
-      Press Ok to close the window, then Press Apply to save the changes
  • Thanks 1
