Ring Motion Events were not getting through to eISY
I notice a light was not coming on when I walked through Ring light with motion.  Finally got around to sorting it out.  I did following:
  • Checked all conditions and the motion event was the only thing missing for program execution.
  • Looked at NS log and events were not showing
  • Restart NS
  • Rebooted eISY
  • Stopped and Started NS
  • Authenticated to Ring
  • At least two times each above
I reinstalled the NS and motion is detected again.  Programs run and can see activity in the NS log works
Let me know if you want me to DM logfile
  • 2 months later...
@hart2hart make sure the remote connection to the portal is still active.
Log into the portal and check from there. In the past mine randomly was reset to no and I just had to reactivate that from the portal side and it worked. It’s been a few months now and others had issues at the same time, but I just checked mine and it’s still “yes”.
If you’re still yes then I’d suggest opening a ticket with UD.
A reinstall of node server fixed the issue back in May.
