v3.0.1 In production channel, v3.1.x in beta
sjenkins
No functional changes, just refactoring and fixing of the variable write features.
see beta Topic for 3.1.x discussion
ISY ACCESS IS REQUIRED , tick box is in configuration for those new to this
variable write cannot work without this since PG3x changes, see code if you are nervous about this
3.0.1
DONE fix get value from variable
3.0.0
DONE add control ability to contact device
DONE refactored to modern template
previous updates:
see udi-Virtual-pg3.py
Edited by sjenkins
3.0.1
3.0.0
previous updates:
Thanks again for moving Virtual forward. Just letting you know that the upgrades are not showing for either beta or production versions.
Thanks for the feedback @hart2hart
Beta store should have version 3.1.0
Production store should have version 3.0.1
Are you referring to the blue message that there is an update available or that the store did not update?
I did not get the blue update message but the new versions were available in the stores and I was able to upgrade into the existing slots on my EISY and POLSY.  I am going to assume the lack of blue update messages is one time as this is my first upload to production.  The UID did reset.
Can you verify you were able to load them into your current slots?
Hi. No they are both still showing the prior versions in plugin store. I updated/reinstalled production and beta versions to see if new version numbers would show afterwards but they didn’t.
Edit: tried with different browser options n case it was a cache issue. Still same.
odd, like I say I verified on two different devices & downloaded from them
I have had issues in the past with updating to the store but that was before they fixed the name change issue.
Could someone else out there verify the versions on the production and beta stores for Virtual ?
8 minutes ago, hart2hart said:
Went for run and back home.
Prod 3.0.1 and beta 3.1.0 now.
thanks @hart2hart ,
the electrons must be running slow tonight
      38k
      379.4k
