Romba Module will not connect after updating to 3.2.27 PG3X
After updating PG3X the romba module is cycling through the following error when trying to start.  Looks like it  cannot find the files.
tried  restart and delete/ reinstall  no change
2024-06-12 08:32:57.143 MainThread udi_interface      INFO     __init__:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MGQ6Yjk6NTY6MGM6MjQiLCJwcm9maWxlTnVtIjo0LCJsb2dMZXZlbCI6IklORk8iLCJ0b2tlbiI6IkpFVi1PWlIlaHl4K0Y4QjMiLCJtcXR0SG9zdCI6ImxvY2FsaG9zdCIsIm1xdHRQb3J0Ijo4ODgzLCJzZWN1cmUiOjEsImlzUEczeCI6dHJ1ZSwicGczVmVyc2lvbiI6IjMuMi4yNyIsImlzeVZlcnNpb24iOiI1LjguMyIsImVkaXRpb24iOiJGcmVlIn0=
2024-06-12 08:32:57.143 MainThread udi_interface      INFO     __init__:<module>: Loading interface module
2024-06-12 08:32:57.665 MainThread udi_interface      INFO     interface:<module>: Loading MQTT module
2024-06-12 08:32:57.932 MainThread udi_interface      INFO     interface:<module>: MQTT module loaded
2024-06-12 08:32:59.188 MainThread udi_interface      INFO     __init__:<module>: Loading udi_interface module
2024-06-12 08:32:59.191 MainThread udi_interface      INFO     __init__:<module>: Loading node module
2024-06-12 08:32:59.192 MainThread udi_interface      INFO     __init__:<module>: Loading custom module
2024-06-12 08:32:59.192 MainThread udi_interface      INFO     __init__:<module>: Loading isy module
2024-06-12 08:32:59.193 MainThread udi_interface      INFO     __init__:<module>: Loading OAuth module
2024-06-12 08:32:59.196 MainThread udi_interface      INFO     __init__:<module>: UDI interface initialized
2024-06-12 08:32:59.196 MainThread udi_interface      INFO     __init__:<module>: UDI Python Interface for Polyglot version 3 3.3.12 Starting...
2024-06-12 08:32:59.300 MainThread udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
2024-06-12 08:32:59.301 MainThread udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/000db9560c24_4/roomba-poly.py", line 19, in <module>
2024-06-12 08:32:59.302 MainThread udi_interface      ERROR    udi_interface:write: from roomba import Roomba
2024-06-12 08:32:59.303 MainThread udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/000db9560c24_4/roomba.py", line 42, in <module>
2024-06-12 08:32:59.305 MainThread udi_interface      ERROR    udi_interface:write: from collections import Mapping
2024-06-12 08:32:59.306 MainThread udi_interface      ERROR    udi_interface:write: ImportError
2024-06-12 08:32:59.306 MainThread udi_interface      ERROR    udi_interface:write: :
2024-06-12 08:32:59.306 MainThread udi_interface      ERROR    udi_interface:write: cannot import name 'Mapping' from 'collections' (/usr/local/lib/python3.11/collections/__init__.py)
Any plans on a work around?  I'm a C++/Assembly programmer, so my sympathies with Python.  My Roombas need light to navigate and it was sort of nice to script it all.
