EISY WLED Plugin Installation
I installed the WLED Plugin on my EISY and cannot figure out how to connect it to my lights.  I looked on Github and was confused with what I saw. Can someone list the steps to connect the EISY to a WLED controller or point me to where they are?  This is the Add Node dialog in the Admin Console for the WLED Plugin. No matter what I try, I get an error.
Ignore that menu on the admin console.  I don't believe it works for any PG3 plug-in.  All configuration should be done using the PG3 UI.
The configuration instructions for the WLED plug-in aren't very clear. My guess is that you have to create a custom parameter with the key being a name and the value being a comma separated list of ip address for the WLED lights. So something like:
key=WLED_LIGHTS
value=192.168.1.4,192.168.1.5
Like bpwwer said, its all in the PG3 interface. Mine is set up as such:
Key = host
Value = 192.168.X.XXX
After saving the changes and restarting the Admin Console it was added.
-K
