landolfi Posted June 28, 2024 Posted June 28, 2024 I have an old Lamplinc 2457D2 that may have finally bought the farm. I try to reset it by holding the set button for as long as 30 seconds, but it does not beep, only flashes green until I unplug it. It is otherwise not responding to any Insteon commands. Is there any other way to bring this back? Quote
kzboray Posted June 28, 2024 Posted June 28, 2024 @landolfi I believe you have to first remove power form the 2457. Here are the factory reset instructions for Insteon devices. https://www.insteon.com/support-knowledgebase/2016/2/24/factory-resetting-insteon-hub Quote
landolfi Posted June 28, 2024 Author Posted June 28, 2024 Thanks, I tried that too. Still no luck. Quote
kzboray Posted June 28, 2024 Posted June 28, 2024 Sounds like it's no longer operating correctly. https://shop.insteon.com/products/dimmer-module Quote
landolfi Posted June 28, 2024 Author Posted June 28, 2024 Thanks! I swapped it for a Zwave plug. I still have one Lamplinc working reliably, and when that goes it will likely be pure Zwave and Zigbee for me with the possible exception of my light sensor/IOLinc combination. Quote
