Instant solar not updating
On the old TeslaPW version 0.3.69 the solar information loads but will not update unless I press the "Update System Data" button. The main other feature I use is "Battery Charge Level" which updates on it's own.
I tried the new udi_TeslaPW2 and although I can not find the "Instant Solar Export" in the AC I assume because of the amount of data does not fit in the AC I did find it in UD Mobile but it shows a value of "99" for that value and a bunch of others.
Solved by tazman
At this time I can not connect to the local IP Tesla is trying to figure out why my Neurios occasionally disconnect. So local access is required? I was running it without local access before and it worked fine but I know Tesla keeps changing things.
I guess I should have stated I'm running strictly cloud based. @Panda88was able to identify what was going on and made a change so the solar is updating regularly again. Thanks for the quick fix @Panda88!
