State variable
@Javi
I have device (door) in my favorites. I use state variables and advanced status configuration to determine if the door is open or closed. When I open favorites the door status isn't properly displayed until I press on the door icon.  If I set the display node to the device rather than to the state variable then the device status displays correctly when the favorites screen is opened.
Is there a way I have the door status correctly display using a state variable rather than the (battery operated) device
Edited by Techman
Solved by Javi
