Change Eisy from Ethernet to Wifi
I've commissioned a new Eisy this week (my 2nd one now in service) and have successfully got it mostly configured, but now I want to physically move it to its new "home" which requires WiFi rather than the Ethernet connection I've been initially using. Where do I make that change?
Also, how do I add a second Eisy to the UD Mobile app? Thanks.
Solved by DennisC
Multi Function Button
(#top)
eisy's power button acts as a multifunction button
Update and Upgrade All the Packages
Click the button one (1) time. Please consult support before updating this route.
Recommended route for updating is through Admin Console -> Configuration Tab -> "Upgrade Packages" button. ‎
NOTE: There is not a speaker on the eisy so there will not be any beeps on reboot.
Go to WIFI Setup or Leave WIFI Setup mode
Click the button two (2) times.
Reset Credentials
Click the button three (3) times This action resets the following passwords to the default (admin/admin):
SSH
ISY on eisy(IoX)
Be sure to change the passwords for these access methods after you log-in again.
Reset Networking
Click the button four (4) times
Reboot
Click the button five (5) times
Shutdown
Click the button six (6) times
Factory Reset
Click the button ten (10) times
Please wait 5-10 minutes after factory reset before attempting to reconnect to system. If System is not found by finder after the wait period please reboot system by clicking the button five (5) times and waiting two minutes for system to come online.
UD Mobile
Quick Start Guides
Existing Portal Users
Upon Installation the app will prompt to setup using ISY Portal. Select Yes.
The app will prompt for ISY Portal login. Select Yes. If app prompts for Portal credentials enter your credentials and save. App may also show a dialog with existing Portal accounts. If this is initial installation select Add New Portal Account.
App will then show a list of ISYs on your portal account or a list of ISY Portal accounts. If a list of Portal Accounts is presented select the Portal account which contains the desired ISY. Select the desired ISY.
Select SAVE at the top right. Then select YES when prompted to synchronize. Wait for synchronization to complete. After synchronization the app will be ready to use on remote connections.
Adding Another ISY (Existing Portal Users)
These instructions assume the ISY is already linked to ISY Portal.
Select Settings-Tab > Systems > Add (top right).
The app will prompt for ISY Portal login. Select Yes. If the ISY is using the same Portal Account as your previously linked ISY(s) select the existing Portal Account from the list. If the ISY is using a different Portal account select Add New Portal Account.
After Portal Account has been selected the app will show a list of available ISYs. Select the desired ISY to add to the app.
Got it figured out. Clearly the mobile app has far more capabilities than the admin console that I grew up with. Thanks.
