Help to get itachi plugin to work
I was able to install the plugin and I had a previous code I was using before but the Yamaha Receiver did not turn on.
I set the plugin to:
key: url value: http://192.168.0.241
key: Master RCVR value: function, code1, hexcode1, code2, hexcode2 "On","sendir,1:2,1,38000,1,1,342,168,23,20,23,61,23,61,23,61,23,61,23,61,23,61,23,20,23,61,23,20,23,20,23,20,23,20,23,20,23,20,23,61,23,20,23,61,23,61,23,61,23,61,23,61,23,61,23,20,23,61,23,20,23,20,23,20,23,20,23,20,23,20,23,61,23,20",,,
I tried to follow the instructions provided and got:
value: function: POWER ON  code1: sendir,1:1,1,38000,1,69,341,170,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,21,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,21,21,64,21,21,21,64,21,64,21,64,21,21,21,64,21,64,21,21,21,64,21,21,21,21,21,21,21,64,21,21,21,1517,341,85,21,3655  hex code1: 0000 006d 0022 0002 0155 00aa 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 05ed 0155 0055 0015 0e47  code2:  hex code2:
The email I received was:
code set: 1674
function: POWER OFF
code1: sendir,1:1,1,38000,1,69,341,170,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,21,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,64,21,64,21,21,21,64,21,64,21,64,21,21,21,64,21,21,21,21,21,64,21,21,21,21,21,21,21,64,21,21,21,1517,341,85,21,3655
hex code1: 0000 006d 0022 0002 0155 00aa 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 05ed 0155 0055 0015 0e47
code2:
hex code2:
Has the format changed?
Solved by Javi
Try restarting the Node Server then check the Node Server's Log.   On restart the plugin will parse the codesets so any errors will be logged.
This looks correct, but the others are definitely incorrect (see https://forum.universal-devices.com/topic/34813-itach-ir-node-server-global-cache/)
I just requested a code set from the control tower database and the format does not appear to have changed.  Also be sure to press the "Send Code Set" Button, do not "select a Function" when requesting the code set.
I wasn't verified on the website and could only get single codes.
I got verified today and was able to get the code set.
After pasting in the new codes and deleting older nodes created while testing, I was able to get it to work.
Thank you for your help.
