Yolink Motion Sensor
In AC under a motion sensor it has buttons for “motion, no motion, and query” They don’t seem to do anything. Also have options for “motion and no motion” under programming but when used in a program they do nothing…
I would like to be able to send an only on command (motion) from sensor like I could with Insteon ms.
Solved by Panda88
I thought that in the app if  I disable no motion state that it would just send motion (on) commands but it doesn’t.
I think it may be filtered at a higher level
I think you can test on Motion under control - it should only trigger when turned on
I tried programming control on but wouldn’t work correctly. Trying to replace all my Insteon ms with these but can’t just replace in programs.even with changing app settings
Edited by drprm1
Can you specify exactly what you need and I can talk a look - I have not looked at the motion sensors for a while so I may be able to improve on them
I think something is wrong with your version
Mine looks like this - you can select if only DON (motion) DOF (no-motion), both and none can be selected
My understanding is that this is want triggers the AC integration outside programs - I believe this is what you are looking for.
The motion and NoMotion buttons are to send a DON/DOF from the device (even if there is no motion)
Does yours look different?
Can you send me a log file with debug enabled and trigger the motion sensor a few times
You can also try to erase the motion sensor and restart the node
I deleted ms from AC. Shut down AC retasrted ns. Restarted AC and the MS showed up in same config as my photo.
This was a new MS added yesterday. Added 3 new yesterday and none look like your example with the on off commands
Edited by drprm1
If it matters it shows in UD mobile a “select command action” prompt. Doesn’t have this in my AC.
Pardon my ignorance. I thought all devices were nodes. So what exactly am I erasing from the node ie from the motion sensor?
Sorry sometimes the nomenclature here escapes me.
Erasing the node in the node server (PG3) does are bigger reset that from the AC - You need to find it in the list there
I doubt it helps when a new node does not work - but may be worth a try
Deleted from nodeserver and reinstalled. Now it looks correct.
Hate to be PIA but what would you expect the buttons at the bottom of screen marked “Motion and no motion” to do. They don’t seem to do anything. In programming “set” to motion or no motion does nothing either.
They are supposed to send trigger (DON / DOF) like the motion sensor would do - allowing you to trigger a scene/program - you can look in PG3 log to see if a cmd('DON" .. ) is sent
I thought it works but I could be wrong
It may not be of much use - I am not personally using them
Doesn’t show up as doing anything. No triggers are sent when using these in programs either.
OK - I can take a look - you are correct
They no-longer work - do you want me to remove them?   Probably no real use
Edited by Panda88
Much appreciated. Would love them to work like and be programmed like Insteon MS. I’ve had a recent ALLON event and would like to take the Insteon MS out of loop and try and use YL.
What function is it you need? - I think you can set the motion sensor to only send on Motion, and when it exists motion (that is the new field)
The 2 buttons are to force a motion event - you can do the same in a program by running the then event
The two buttons don’t force a motion event nor does running the then event in a program containing a motion or no motion command. At least I can’t get it to.
I can get it to only send on or only off commands but the buttons I would think would override the setting.
I’ll jack with it more.
Edited by drprm1
The buttons are not working now
I can enable them again - I removed them, but forgot to remove them in the profile so they show up but with no function
I think you need to test the sensor working
From what I can see (besides timing) it should offer then same as the insteon (I have)
It can trigger only on alerts or trigger on both alert and when no alert happens - My node further offers to only trigger on no_alert
Note, it send DON for alert and DOF when no_alert happens
