Yale Door Lock YRD226 Z-Wave - no user codes supported in EISY
I've just migrated from an ISY-994i with a 500-series z-wave card to EISY with a Z-Matter dongle. My question pertains to z-wave functionality for the Yale door lock model YRD226.
On the ISY-994i, I was able to set user codes in ISY and send out notifications for particular users (think housekeeper) upon unlocking the door. It appears that this functionality isn't supported under EISY/Z-Matter.
Is it possible to bring over the exact same functionality that was supported with the ISY-994i and series 500 z-wave card?
Blaine
Edited by blaine
typo
Solved by dbwarner5
Blaine
There may have been something wrong when you migrated your zwave devices. I used to have that lock. Everything you're stating that's missing was/is supported.
Edited by lilyoyo1
Check the "children" under the main lock and users should be present. This access control is also used in programing.
if you dont have it, then you may need to do a "interview" to get it to show up properly. See screen shots below.
