Issues after installing Tesla powerwall 3
can you provide a link to the filter you got, and Price for unit and install?
NCSTATE1978 on page 4 of this disccussion gives an image of the Enphase filter that solved his issues, which were the same as ours (blinking and communication lag)..
@NCSTATE78 I know it sounds like I am stalking you, but you appear to have solved the problems that I am also experiencing.
Currently, my installer is recommedning a Gapped Ferrite (65 A) filter on 4 lines. If I recall correctly, this was a "solution" that sort of worked, but not completely.
Is there an way for my installer to contact your installer to discus your specific installation to see if we are similar. I wish I knew of a way to Private Mesaage you so I could give you my email address so we could exchange the information that would better ID us for the installer communicaiton.
You can give it a try. My installer missed installing the ferrite cores that come with (and are placed inside) the powerwall3. They installed those and that did not help with insteon. The filters you referenced aren't the same, but are similar to those that tesla provides, so while I don't have experience with those specifically, Ferrite cores in general didn't make a difference for me.
The service manager that helped me with this issue no longer works for my installer and without a direct contact, it's not likely you'll get very far without hiring them to service your system.
You can try the ferrite cores, but if those don't work, as I mentioned before, I can tell you that the filter I posted above worked for me.
@jkraus I did a little Google search using RPC1508-64. Several good hits. The Enphase page gave me a price around $420. There were some imdependent sources that were around $350 and EBay source in the $230 range. Obviously, there were would be an installation charge and electricians are not cheap.
@NCSTATE78
Thanks.
Strange that my installer (who does not have a forum id/pw) can no longer see this thread.
  • 3 weeks later...
I thought about installing a filter to resolve my communication issues, but my installer refuses to do this. They claim that Tesla has told them it will void any and all warranties. Anyone else hear this?
No. One of the engineers with my installer has been working with Tesla on this very issue. He, along with Tesla, developed a Ferrite Core, similar to one discussed in this thread. They are familar with the Enphase In-Line filter that was the solution for NCSTATE1978. Right now, they are working on estimates for both solutions. I want to know the difference in the labor and other materials since they did say they would refund the cost of the Ferrite Cores if those did not work. They are leaning towards the Ferrite Core since it has been successful in a couple of other installs. However, I do not believe the other installs had INSTEON or EISY as part of the environment. Just dimmer switches.
As far as I can tell, Tesla is aware of the issues and has not said anyhting about voiding the warranty.
  • 3 weeks later...
I've landed here after searching about Powerwall 3, Insteon, and flickering. My Powerwall was installed a couple of months ago and I've seen comm. issues and flickering since. The comm issues are minor esp. compared to the flickering. I'm not sure which is the bigger stress'r: all the flickering or a family member who wants me to get Tesla back here to yank out the PW3 and restore things to they way they were.
I contacted Tesla Energy and after five or six attempts (using their online support) I eventually called and spoke to someone. Long story short they told me the Insteon devices are not compatible with the Powerwall and that I should go buy Lutron dimmers. Not exactly what I wanted to hear.
I've installed many Insteon devices over the years and found their system handy especially when coupled with the automation features of the EISY + PLM. I don't want to give that up however I am willing to put in some money to replace problematic Insteon dimmers esp. if I can quiet down some of the flickering and noise. I've read all posts in this thread (probably twice) but I only know EISY+Insteon+PLM. Some posts have mentioned dimmer devices by other vendors that use other protocols (ZWave/Zigbee/Matter) but I'm not clear: do these work with EISY and can I control them from various Insteon devices? Is the PLM sufficient to talk to these? I'd like to continue to have my Insteon keypad buttons turn on and off some of the dimmers I'd need to replace, would that still work (I've now read too many search results but somewhere there was mention that ZWave devices don't work with scenes)? When I look at one of the vendors (INovelli) their web site does not mention UD EISY as a compatible controller (in fact their AI-bot says it is not supported).
Thanks. Trying to get a handle on how big an expense solving this flickering issue could be. Seems like the easier battle to win esp. given how poor Tesla Energy is at support.
@NightStorm If you "talk" to NCSTATE1978, he will tell you the inline filters completely solved his problem. Right now, my installer (in the DFW Area - Good Faith Energy) is getting ready to install the Ferrite Core solution. I am keeping my fingers crossed. The cost will definitely depend on your installers labor cost. The materials for the Ferrite Core solution are about $400 and the In-Line filter (look in the NCSTATE1978 post for the part number) will run about $900. The in-line filter will require about 3 hours of labor whereas the Ferrite Core labor is about 1 hour. There are some additional materals needed for the In-Line Filter. [Numbers assume a 2 PW3 installation]
The blinking or flickering is rather annoying. It only affects my dimmer switch installations. What is really annoying for me is not knowing if the programs will function as they did before PW3. Plus, you can not diagnose anything because the communication timing is all our of whack. I had some earlier Lutron devices, but really was not impressed by them. I am sure they have improved since then. I am considered some of the Z-Wave/Zigbee/Matter devices for outside. However, I really am dependent on scene programming. You can turn off your batteries to make sure everything really is working and perform a diagnosis.
Keep working with your installer. Show them this thread. I will say the minute I sent this thread to my installer, it went private or required a login.
Any updates to this topic?
I, too, am experiencing terrible flickering problems since have my Tesla battery installed. We reported the flickering before they even left our property on the day of installation. The installer has been here three times, and their "master electrician" has also come three times. They took apart all of my panels (I have four panels, because we have built on twice, and finished the basement--all of which would not fit onto the original panel), and rewired them, making sure all the neutrals were not tied to the grounds.
Still flickers! I will try replacing a few of my Insteon dimmers to see if that solves it. HOWEVER,
The thing I am really concerned about is this: if there is unstable power, it will have a terrible effect on anything electronic--sooner or later. It may be coincidental, but since we installed the Tesla battery we have had all of the following items fail: electronics on gas range; 3D printer electronic problems; modem and router problems; Insteon devices not responding quickly and flashing red; Universal Device hub lagging or not responding at all; electronic tub/shower valve failed THIS MORNING; and who knows what else is on the verge of going out!
I appreciate all the advice I have read herein. If there is any new information, I would love to hear it.
I just moved the Insteon dimmers I could where they would not flash and left the Keypadlincs for obvious reasons. They still flash if I am using the dimmer on A but I have not had any electronics die since the Powerwall 3s were installed in Dec 2024. It's not for a lack of electronics either. :) If there was a Keypadlinc alternative I'd replace those too but sadly there is not. At least not with 8 buttons for a reasonable price. Curiously I only see flashing when the Powerwall 3s are the only source, not when solar or the grid is powering the house. I did have a slow UD hub until I upgraded to the EISY from a Polisy. Sorry I am no help.
I had some flickering in a few places (not PW3 related) that was loosely associated with Insteon powerline traffic affecting dimmers. I originally put dimmers in those locations "just because", and the reality is that in several years they've never been dimmed. The imbedded micro module dimmers are affected the most.
I replaced the micro dimmers with on/offs, and in one room set the i3 paddles to relay mode that stopped it. This may not be the ideal solution for everyone, but worked for me. No more WAF issues.
Did they check you main neutral lug on the meter or main breaker: after all the problems and me replacing all my Insteon with non powerline switches, Tesla finally game out and the neutral needed 3 more turns at the fist place neutral and grounds were bonded. I lost some electronics during that period including soft starts on my ac units.
We tried the Ferrite Core solution. It helped a little bit. We could see slight improvements on the O-Scope, but the flickering still is happening. Sometimes my scenes works as scheduled. Just completely random. We have ordered the filter that was referenced in an earlier post. The installation is a little bit more involved than the Ferrite Cores. No problems with any electronic devices in the house. TV's, AC units, furnance, tankless hot water heater, Mesh network, internet, ..... are all functioning as expected.
You might want to shut your PW3's down. After doing that all of your Insteon and eisys devices should function normally. That will verify the PW3's are interfering with the nornal sine curve of the electricity in your house. Insteon devices according to my conversation with the engineers there like the sine curve to between 59.5 - 60.5 Hz. The stuff coming out of the PW3 was around 62.5 Hz. The only time everything appeared to function normally with the PW3, other than when I shut them down, was when the Severe Weather mode charged all my PW3's to 100%.
Hello cksedg,
Have your electricians or Tesla reps used a Power Quality meter or logging oscilloscope to monitor your power over some time period? This should be done both with the PW3 connected and also when the PW3 is isolated from your power. I would be concerned if you have lost that many electronics since the install.
It appears the PW3 needs to have a proper EMI filter installed to remove the interference frequencies that are affecting Insteon. The proper filter is not ferrites. It is a large EMI filter that incorporates larger inductors.
  • 3 weeks later...
Just thought I would give an update to this adventure. As you may recall, I had 2 Powerwall 3's along with 2 Gateways installed. Almost immediately, I experienced flickering of all lights (LED) that were connected to Insteon dimmer switches. That is when I came to this forum. We tried the Ferrite Cores primarily they were the least cost (my installer was trying to look out for my wallet). They really did not work Last week, we installed the EMI filters that hopefully will show up in the attached picture. Immediately everything went back to normal. Flickering disappeared, scenes programmed into the eisy started funtioning again as programmed and expected, and accessing devices in my eisy network could now happen again. So, I would say mission accomplished.
If you want to know more, my installer is Good Faith Energy in Addisson, TX. Amanda Haines was my project manager.
Apologies - they were installed upside down from the label standpoint and I was too lazy to rotate the photo.
BTW - These are the same filters discussed by NCSTATE1978 is the early days of this topic thread.
Also, to those that have only one powerwall, you’ll only need one filter and it’s therefore possible to fit it inside the gateway enclosure.
Also, anyone else have issues this weekend with solar going to 0 and powerwall 3 saying it was 0% charged when I know it was not and other weirdness with 3rd party apps like Netzero and the PG3 plugin? I was afraid Tesla had changed the API again. I powered off both batteries and back up and it seems to have cured it for now.
Edited by btreinders
I had something weird happen this weekend where my power wall Gateway showed that the grid was disconnected. I have two gateways in my system. One of them is fine. The other show disconnected. I had no message in the Tesla app. There was no grid failure. I simply clicked on it and said reconnect to the grid and it came back up no problem, but I have no idea why it just randomly disconnected and was essentially just using the battery beyond its backup setting
@bigDvette It might have been a momentary low grid voltage where one Gateway started to react and the other one did not need to react since the voltage was back to OK. Probably a software glitch in the app or gateway that did not reconnect to the grid.
@btreinders I left you a PM about the rought cost.
Are you aware that the PowerWall 3 battery technology cannot keep track of 100% and 0%, so periodically, they will dump the batteries to the grid until they are depleted to 0% in order to find that data point, then next day, sunshine permitting, will start charging back up.The Powerwall 2's do not have this "problem". Perhaps that is what was happening.
The apps grab data from Tesla, so they can only report what Tesla posts.
If indeed the Powerwalls are doing their "calibration", then powering off will only postpone the dump. It will happen again very soon.
Edited by nowandthen
