I added memory, but now want to remove.
I added memory to my eisy per this article:
https://developer.isy.io/blog/NVMe/
I did so in anticipation of adding a VM with Home Assistant per this article:
https://developer.isy.io/blog/Home Assistant
I added the memory, but I did not install the VM.  I went a different direction and now I would like to remove the memory from the eisy to use somewhere else.
Do I just pull the memory stick out and that's it?  Or do I need to enter some commands in terminal first?
I would suggest asking UD this question via a support ticket.
