Need help setting up pw3
I guess I’m being an obtuse and not understanding how to set the note server to see my Tesla power wall three. I’ve plugged in my email and password ID and I don’t see anything appearing within my network. (Note removed password for pic)
if someone could give me some detailed help on how I should fill in this profile so I can get it to work properly please let me know. I’ve deleted my email for login for this picture and I know the local ip address which is 192.168.0.32
Edited by richtimpa
Added pics and info
5 hours ago, Panda88 said:
If you PM me a log with debug enabled I can see what happens
Thanks for the quick response in my inbox. How will I know when to update it
Christian
I’m not sure I understand exactly what you’re saying. I see that the app you wrote is at 1.26 and polygon is at 3.2.27.
what exactly is  3.3.16
What exactly are you telling me to do?
sorry for being so obtuse.
I am referring to the build of the PG3x - it needs to be 3.3.16
I think it is released now - my other system just updated.
Go to AC (Admin console) and select configuration and upgrade packets.  It will update for a while
If upgraded successfully it should look like this in the web interface
If ok try to do an install again
Christian
I’ve tried to reboot and mine is still at the same number 3.2.27
I’ve tried the update packages twice and rebooted twice now
i also deleted the teslapp app in case that’s holding it up  the forum doesn’t show any update to this as well
Edited by richtimpa
it took me a while for it to take effect - not sure why - check tomorrow and see if it is updated
The update is a question for Universal-devices - I do not have any control over this - you need minimum 3.3.6 (I think it is) to get the node working (to support OAUTH)
Christian
ok I’ll check tomorrow by updating packages and rebooting again and will also check with universal devices on why it isn’t upgrading
Edited by richtimpa
Btw. How come you have a version so far ahead of me?  Don’t understand why I have not seem updates since I’m sure others are using your node.
Same here, I just had 2 powerwall 3s installed and the plugin would not work.  I updated packages and PG3x still shows 3.2.27 and I don't see a version beyond that in the official current versions page.  If it isn't officially released yet how do I manually update it?  Choose install DEV packages? Thank you in advance.
Edited by btreinders
When installing the node a version update should be forced - it needs 3.3.x to support OAUTH.  It may be a display issue but this is an issue in PG3.  I would contact universal-devices to get help on this one
I got an answer from Universal devices, and they said that in order to run that version of polyglot, will requires our latest OS 14.x which will be release by the end of the week.
hopefully when it comes out, we will be able to run and install 3.2.27
On 12/9/2024 at 3:00 PM, Panda88 said:
Keep fingers crossed - continuing to work on it - I will have an updated version soon - with some more bug fixed
Still waiting for the iOS upgrade and just fyi
