Works with Vue3 ???
Hi All, @bpwwer
  I would like to buy a new Vue3 but only if it works (or can easily/quickly work with some tweaks) with the Node Server.
Please let me know ASAP as I need to take advantage of a current sale price.
Shawn
Solved by tazman
I have a V3 that works just like the rest. Since the information is being pulled from Emporia I would bet the Plugin does not know the difference.
I only have one old Vue device so I can't personally confirm that Vue 3 devices will work.
There isn't anything in the plug-in that would block or stop it from working with Vue 3 devices as long as they are still using the same API.
Thank you @tazman and @bpwwer for your info.
From what I can see, they only now sell the Gen3 so I would expect to start seeing more of them. I would not have guessed them to be much different - from what I know, the CT's have been redesigned "for better accuracy", and the control box is a new shape with an added Ethernet port for those who have signal trouble with the wi-fi. Other than that I believe all the "functions" are unchanged, so I was hopeful.
But again, great news. Thanks!
