AvRemote fails to install
I installed AvRemote but initially it fails to install. It remains in disconnected state. It did become connected at one point but caused the eisy to display the system busy window over and over again which would go on forever. It worked fine from the main screen but programs would go busy but would not work.
V 5.8.4
Thanks Gary
V 5.8.4
Thanks Gary
I've tried installing it now again - it finished installation properly but gave some UDX error. Will try to work it out with UDI.
Once installed, I was able to start it with no issues. Seems fine.
It turns out that the eisy was busy trying to communicate with zwave devices that were no longer available. So I think it just didn't have the resources available to start up. After clearing the problem with zwave it did start up and has been working fine since than. Thank you for taking a look. I should have updated this post.
