ZooZ 800 USB ZST39 LR
Is this compatible with the Polisy, will I get longer range if I have 800 devcies, and is it just plug and play i.e. no configuration?
Not sure if the ZST39 is compatible but if it is, the 800 series has longer range than the previous versions but your zwave network would be contstained by the devices that are not the 800 series. You could open a support ticket with UD to find out if it's compatible.
I've attached the 800 series datasheet.
Zwave 800 datasheet.pdf
I don't see why it wouldn't be. I'd buy it from Amazon. If it doesn't work, send it back
