Newbie questions trying to get started Polyglot 3x
I have read through Polisy:User Guide, but not grasping the big picture of how this works
I am able to login to Polyglot 3x, first thing I see is this page, I searched through DOC's and the forum, can't find anything to explain what isylink is ??
I then tried to install something simple like PING, but get a big red error
any help getting started would be appreciated
Solved by DennisC
Unmanaged means pg3x doesn't know anything about that item and therefore can not manage or display information about it. It was installed outside of Polyglot version 3.
Make sure your ISY (which machine are you using?) is connected to pg3x by going to the system tab.
Edit - you can also try a power reboot.
Edited by DennisC
Added reboot.
I found and removed ISYLink from plugins / configure ...
Rebooted, connected Polyglot 3x, still get errors trying to install PING
Looked at the Log, can someone translate please
2024-12-19 09:04:25.307 [pg3] info: ------------------------------------------------------------
2024-12-19 09:04:25.309 [pg3] info: Starting PG3x version 3.2.27
2024-12-19 09:04:25.309 [pg3] info: Using Workdir /var/polyglot/pg3/
2024-12-19 09:04:25.313 [pg3] info: Starting sqlite database at /var/polyglot/pg3/pg3.db
2024-12-19 09:04:25.335 [pg3] info: Encryption key found ID: XXX long key XXX. Database version 1
2024-12-19 09:04:25.339 [pg3] info: Query IoX for platform UUID.
2024-12-19 09:04:40.991 [pg3] info: ------------------------------------------------------------
2024-12-19 09:04:40.992 [pg3] info: Starting PG3x version 3.2.27
2024-12-19 09:04:40.993 [pg3] info: Using Workdir /var/polyglot/pg3/
2024-12-19 09:04:40.996 [pg3] info: Starting sqlite database at /var/polyglot/pg3/pg3.db
2024-12-19 09:04:41.001 [pg3] info: Encryption key found ID: XXX long key XXX. Database version 1
2024-12-19 09:04:41.005 [pg3] info: Query IoX for platform UUID.
2024-12-19 09:04:41.028 [pg3] info: Found IoX with UUID XXX MAC ADDR XXX
2024-12-19 09:04:41.033 [pg3] info: Loaded globalsettings successfully. Database version 1
2024-12-19 09:04:41.035 [pg3] info: isys currently in table: [{"id":"XXX long key XXX","uuid":"XXX MAC ADDR XXX","name":"IoX","ip":"127.0.0.1","port":8080,"username":"#####","password":"#####","enabled":1,"discovered":1,"version":"5.8.4","secure":0,"timeAdded":1734381793822,"timeModified":1734616900181,"dbVersion":1}]
2024-12-19 09:04:41.036 [pg3] info: isy table: Loaded (1) successfully
2024-12-19 09:04:41.036 [pg3] info: IoX: XXX MAC ADDR XXX 5.8.4 127.0.0.1 XXX long key XXX
2024-12-19 09:04:41.038 [pg3] info: nodeserver table: Loaded 1 nodeserver(s) successfully
2024-12-19 09:04:41.040 [pg3] info: store is up-to-date
2024-12-19 09:04:41.054 [pg3] info: Forcing custom certificates to off
2024-12-19 09:04:41.057 [pg3] info: Updated configuration with overrides
2024-12-19 09:04:41.058 [pg3] info: Setting PG3 log level to error
2024-12-19 09:04:41.149 [pg3] error: Failed to get node server store https://pg3store.isy.io/v2/list :: Error: getaddrinfo ENOTFOUND pg3store.isy.io
2024-12-19 09:04:41.150 [pg3] error: (catch) Failed to get node server store https://pg3store.isy.io/v2/list :: TypeError: Cannot read properties of undefined (reading 'data')
2024-12-19 09:04:41.150 [pg3] error: Failed to get any data from Production store...
2024-12-19 09:04:41.155 [pg3] error: Failed to get node server store https://pg3betastore.isy.io/v1/list :: Error: getaddrinfo ENOTFOUND pg3betastore.isy.io
2024-12-19 09:04:41.155 [pg3] error: (catch) Failed to get node server store https://pg3betastore.isy.io/v1/list :: TypeError: Cannot read properties of undefined (reading 'data')
2024-12-19 09:04:41.156 [pg3] error: Failed to get any data from Beta store...
2024-12-19 09:06:52.627 [pg3] error: transactionReport: uuid XXX MAC ADDR XXX not found in portal account
2024-12-19 09:07:01.373 [pg3] error: transactionReport: uuid XXX MAC ADDR XXX not found in portal account
2024-12-19 09:10:11.051 [pg3] error: transactionReport: uuid XXX MAC ADDR XXX not found in portal account
2024-12-19 09:10:30.346 [pg3] error: transactionReport: uuid XXX MAC ADDR XXX not found in portal account
2024-12-19 09:11:03.660 [pg3] error: transactionReport: uuid XXX MAC ADDR XXX not found in portal account
2024-12-19 09:11:09.856 [pg3] error: transactionReport: uuid XXX MAC ADDR XXX not found in portal account
2024-12-19 09:11:43.195 [pg3] error: transactionReport: uuid XXX MAC ADDR XXX not found in portal account
2024-12-19 09:11:45.742 [pg3] error: transactionReport: uuid XXX MAC ADDR XXX not found in portal account
2024-12-19 09:12:17.023 [pg3] error: transactionReport: uuid XXX MAC ADDR XXX not found in portal account
2024-12-19 09:12:23.423 [pg3] error: transactionReport: uuid XXX MAC ADDR XXX not found in portal account
2024-12-19 09:12:28.896 [pg3] error: transactionReport: uuid XXX MAC ADDR XXX not found in portal account
2024-12-19 09:12:32.753 [pg3] error: transactionReport: uuid XXX MAC ADDR XXX not found in portal account
2024-12-19 09:26:22.897 [pg3] error: Failed to get license
2024-12-19 09:26:22.897 [pg3] error: AxiosError: Request failed with status code 404
2024-12-19 09:26:22.897 [pg3] error: getNewLicense: TypeError: Cannot read properties of undefined (reading 'statusText')
2024-12-19 09:26:23.243 [pg3] error: transactionReport: uuid XXX MAC ADDR XXX not found in portal account
2024-12-19 09:26:29.641 [pg3] error: Failed to get license
Edited by jim_
Have you registered and approved your device (easy/policy) in the portal?
Follow directions in wiki to add your device in portal and then approve in admin console.
Thanks to DennisC for the help ...
For anyone who is new ISY or eisy and reading this thread, in the main Wiki, there is a DOC named ISY Portal Installation Instructions ... You will need to register the MAC address of your UD device, then approve it on the Admin Console
Edited by jim_
Now I can add the plugin PING, and while there is configuration help, there is no field to enter a IP Address
The only editable fields are the PING duration timers
Again help ... (
Edited by jim_
