Replaced a few nodes, Now, EISY is unresponsive
I replaced a few Insteon switches that had burned out but when I went to start linking them, the EISY wont run the link management tool.
I then tried controlling some switches from the administrative console and I get "Request Failed"
Then I got this:
Never seen this before.
What is going on?!?
here is what i'm running:
Solved by paulbates
There's a couple of things to look at
  • How old is the plm? Post the 4 numbers on the white sticker on the back of you don't know the year you bought it. Is the LED by the set button lit? It should be.
  • If that checks out or the plm is new: when I first set up my eisy that happened to me and I had to restart eisy several times. Then it was good.
Edited by paulbates
Here is a picture and the LED is lit.
do I just keep restarting the EISY?
this?
I have restarted 3 times and still get the not connected status?
What about a PLM restore?
Yes, that looks right.
There's a catch-22 with the PLM restore.... you have to be connected to do it.
Try
  • powering down the eISY
  • Unplug the the plm
  • Unplug and firmly replug the plm's cable to the eISY on both ends
  • plug the plm back in
  • wait 10 seconds, the start eisy back up
Edited by paulbates
That worked! I am connected. I replace the USB cable just to be on the safe side!
Thanks!!
