Smart lock addition
Got a new smart lock from Yolink. The fingerprint deadbolt YS7616-UC. I realize it’s new and maybe not supported yet but it is classified as a smart lock which I believe is supported? Anyway I’ve done everything to try to get it to show up in AC with no success.
Is it supported yet?
thanks!
Solved by Panda88
Are you using hte yolinnk plugin? Yolink devices wont show in EISY or the AC as they use their own proprietary long range signal.
The plug in is the "interface". You also need a YoLink hub..
Maybe stating the obvious here, but just trying to clarify where to start with trouble shooting.
Yes I have a hub and yes  I use the Yolink plugin. I have about 30 other Yolink nodes that show up in the AC…..all except my new lock. Was hoping Panda had a solution here.
Edited by drprm1
Can you send me (message me) a log with debug enabled - I only have the old lock and it works - it may need a new Driver - I should be able to see from log
I hear back that there is a new API, but be old one may work ok for now  - the new one is not released yet
Still not showing up in AC
Assume you want log. Will send it in morning
Edited by drprm1
Pardon my ignorance here but are you saying to install the test node in its own slot to see if my lock shows up?( don’t want to mess up what I already have)
look for 1.3.11 in the non-production store - testYolink node
yes - you can store in a separate node (maybe stop your existing one while testing)
Make sure you install again - I forgot to add the new lock in the previous version
I seems you got an earlier version where I limited the devices (and not included the lock) - I just put 1.3.12 up - try to update - it may take a little before it is ready
Also tried deleting test node and reinstalling in new slot. After configuration  it never shows  connected. When I try and start it show “already running” but it’s not connected.
log is empty
Still shows 1.3.12 in store?
sorry, refreshed and got it.
Edited by drprm1
It takes some time to propagate - you can try refreshing the page but it can take up to a couple of hours before posting
installed 1.3.13 and still not showing connected. Restarted several times and not connected
